Latest Virtual VP running on windows 7 32 bit. Weatherlink 5.9.2 Cumulus and WD all running. Connection is via serial too usb.
I’m now getting the following error
12/04/10 8:57 (derbyvp2) Error reading data from the Station.
12/04/10 8:57 (derbyvp2) We did not receive an acknowledge to our last command. Please try again.
12/04/10 8:57 (derbyvp2) GetAcknowledge () response: 0x0A (should be 0x06 )
12/04/10 8:52 (derbyvp2) Unable to upload Data Upload Profile(s) 3 because of errors. See error messages below.
12/04/10 8:52 (derbyvp2) Error reading data from the Station.
Yet the data is downloading so at the moment I’m ignoring it. However it was fine a few days ago.
Machine has been restarted but still the same problem.
I read your message, I have exactly the same problem with VirtualVP:
03/05/10 18:55 (truc) Unable to upload Data Upload Profile (s) 1 2 Because of errors. See error messages below.
03/05/10 18:55 (truc) Error reading data from the Station.
03/05/10 18:55 (truc) Function to retrieve data-through TCP / IP protocol from the device timed out.
03/05/10 18:54 (truc) Unable to upload Data Upload Profile (s) 2 Because of errors. See error messages below.
03/05/10 18:54 (truc) Error reading data from the Station.
03/05/10 18:54 (truc) We Did Not Receive ACKNOWLEDGE year to o last command. Please try again.
03/05/10 18:54 (truc) GetAcknowledge () response: 0x0A (0x06 Should Be)
try instead using an earlier version of WL, i.e 5.8
as 5.9 version seems to be wanting to use LOOP2 mode, which VVP does not have support for (and means different data length/time out or similar I would say)
Actually just checked and the file is supposed to be updating isn’t.
Next question there hasn’t been any responses from Steve about this. Is he on holiday, ill or just given up for a while.
There is an issue with Weatherlink v 5.9x. I don’t know if it has to do anything with VVP.
Fore some reason, it stops uploading files on the Internet! It starts the sequence, reads the data
from the datalogger and that’s all.
The settings are the same with previous versions (v.5.8x).
Then I go back to version 5.8.3 and everything is fine! :?
I use WL together with WD just to get some handy reports.
