Author Topic: WD Mac Intel - New Install and Upgrade Info  (Read 53759 times)
Offline [email protected]
  • Traveling in the West & Southwest U.S.
  • Southwestern U.S.
    • RoadRunner
Re: WD Mac Intel - New Install and Upgrade Info
« Reply #30 on: December 07, 2010, 02:00:30 AM »
They are the same as the folder. I wonder if I completely remove WD from the computer and reinstall it if that might make a difference.
Davis Vantage Vue
iMac 27" 3.4 Intel Core i7
OS X 10.9.1 Mavericks
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #31 on: December 07, 2010, 02:09:55 AM »
are there any start up errors under view, program error log?
also make sure there is no wdisplay.ini file in the application bundle, contents, macos
also you should really not be posting in this thread, you should have started a new thread
  • Southwestern U.S.
    • RoadRunner
« Reply #32 on: December 07, 2010, 03:29:36 AM »
There are two errors listed: error with longitude, error with latitude. I do not see any wdisplay.ini files other than the one in the library. There are none in the application bundle, contents or Mac OS. Is there a way to move this posting to a new thread.
Davis Vantage Vue
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #33 on: December 07, 2010, 04:50:36 AM »
Quote
thats the problem
you have incorrectly setup the sun moon rise/set setup
I suggest deleting the wdisplay.ini file in /Library/Application Support/wdisplay/
(when WD is not running)
then start WD
it should start up as brand new, no setttings
then setup again
(and post your sun moon rise/set  up once you have set that up)
  • Southwestern U.S.
    • RoadRunner
« Reply #34 on: December 07, 2010, 06:43:28 AM »
That did it. Seems to be working fine now. Thanks a lot for your help.
Don
Davis Vantage Vue
Offline Sharmo
  • Tarnagulla, Vic, Australia
« Reply #35 on: May 03, 2011, 12:20:23 PM »
I have followed the instructions but my WMR200 cannot see the USB however it is shown in the System Profiler:
Universal Bridge:
  Product ID:   0xca01
  Vendor ID:   0x0fde
  Version:    3.02
  Speed:   Up to 1.5 Mb/sec
  Location ID:   0x3a200000
  Current Available (mA):   500
  Current Required (mA):   100
Help please as I don't want to continue using the Windows version any more!
Sharmo
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #36 on: May 04, 2011, 03:40:13 AM »
you will need to use weathersnoop
and then set that to data share
then set the latest .zip Mac version of WD to get the data from weather snoop
(restart it after setting that)
Offline Blueruck
  • Colorado - USA
    • Vist my station
« Reply #37 on: May 19, 2011, 01:48:32 AM »
Thanks guys for all of the good info.
The last PC in my house is my weather station. I just ordered a mini and will begin the process to migrate years worth of WD data to my Mac.
I'm looking forward to a machine that just runs and runs and runs without needing a reboot each week nor having a weekly blue screen.  It took me a few years to move to a VP2 and even longer to say goodbye to Windows.
Offline mfd38
  • Massachusetts
    • Medfield, MA Weather
« Reply #38 on: May 19, 2011, 06:30:08 AM »
Hi Blueruck, just be aware that Brian has been having difficulty supporting the mac version lately. It seems his mac is acting up and makes it difficult for him to address any issues. He went as far as to briefly remove the mac version from the download page. Hopefully he'll be able to continue to support the mac version, otherwise it may become necessary to resort to using Parallels or similar if you desire to keep using WD.
Offline Blueruck
  • Colorado - USA
    • Vist my station
« Reply #39 on: May 19, 2011, 10:32:23 AM »
Thanks MFD,  I looked up your station location and I will be very near you today.  I'm running from RI to Logan later today to fly home.
I'm looking for stability, if WD for MAC loads up and runs great I will be happy without any future updates.  I travel a lot for work and it is a pain to find your weather station crashed and trying to walk the wife through bringing it back up, switching comm ports etc.  I just want something that will run.
Is the MAC version of WD stable?  I have a mini on the way to the house, but I can return it if unopened.
Offline mfd38
  • Massachusetts
« Reply #40 on: May 19, 2011, 04:17:47 PM »
Hi Blueruck,
The mac version is quite stable. I'm not sure that the latest release of build 80 is as good as previous builds, there seems to be an unfinished post on some issues with build 80. Taking a quick look around at members sites I see that several, including myself are using build 77. I know that builds 69 and 63 are also good builds. I did not see anyone using build 80.
A couple of things you should know about the mac version. One is that as far as I know several members have issues with the upload of the climatedataout files at the end of the month. In my case I need to recreate them at the beginning of the new month and upload them. There are a few posts on this issue.
Another more noticeable item, especially if you have been using the windows version of WD is the fact that the mac version lacks a lot of the usable features that exist on the windows version. The user interface is not as complete or functional as it should be, but it's enough to get most data uploaded ok. For example, on the mac version it is very difficult to customize the main screen, I can't do it :-(.  Also, you may find that some of the control panels are truncated which will prevent you from doing certain tasks. One example of this is if you wanted to edit the log files/rain totals using the View and Modify Log File/Rain Totals panel, you may be unable to fully access all dates for the rain totals. Quite annoying when you have the need.
I'm not bad mouthing the mac version, Brian has done the best he can with it for the moment. I tolerate the inadequacies of this version for a few reasons: First, for me anyway there is no other weather software that is compatible with my Rainwise data logger and mac osx, at least not with the capabilities of WD;  WD for mac, even in it's reduced functional state as compared to the windows version is a work horse;  I have no desire to return to using windows at this time; and lastly the support available on this forum is outstanding. You'll also find great support on the WXforum http://www.wxforum.net/ for general weather items and many of the scripts used on websites.
I hope this helps,
Paul
« Last Edit: May 19, 2011, 04:22:41 PM by mfd38 »
Offline Blueruck
  • Colorado - USA
    • Vist my station
« Reply #41 on: May 19, 2011, 05:49:33 PM »
Thanks Paul,
Does someone have a copy of 77 that I can download?  I didn't see it on the WD site.
Offline mfd38
  • Massachusetts
« Reply #42 on: May 19, 2011, 06:08:18 PM »
Can you PM me your email address, I can get you a copy.
« Last Edit: May 19, 2011, 07:26:28 PM by mfd38 »
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #43 on: May 20, 2011, 10:18:07 PM »
the problem with the climatedata files should be fixed in build 80
but is there no one using build 80 you say?
Offline mfd38
  • Massachusetts
« Reply #44 on: May 20, 2011, 11:44:28 PM »
Hi Brian, just taking a quick look at some of the more active members on the forum I did not see anyone using build 80. I did not intend it to sound like no one at all is using it, just the sites I surveyed were not. I have yet to try build 80 myself, I was waiting to see what the outcome of NorCal Dan's post was (http://www.weather-watch.com/smf/index.php/topic,51013.0.html) before I tried it however looking at his site I see he went back to build 77.  Also other members reported issues with build 80 in the same post.
I'll give build 80 a try and let you know how it goes.
Paul
« Last Edit: May 21, 2011, 12:07:22 AM by mfd38 »
