Hi guys,
i have ver. 3.00 of this file…could i install the new version without problem?
I’ve attached my ajaxWDwx.js file.
Many thanks,
Alessandro
P.S.
Welcome back Ken!
ajaxWDwx.js.txt (41.1 KB)
Hi guys,
Many thanks,
Alessandro
P.S.
Welcome back Ken!
Should not be a problem … the Webster Weather modifications have been added to this script.
Hi Rainer,
could you explain me how to use new version of ajaxWDwx.js?
I’ve installed it but it seems to change nothing in my site.
I’ve seen that the new version has a lot of customization but i don’t know how to use some/all of these.
Should i upload the ajaxWDwx-settings.js too?
Many thanks,
Alessandro
Yes, I suggest you use “ajaxWDwx-settings.js” for your setup and then upload it to your server.
This will ensure that you won’t have to make changes to it again for the next upgrade.
However keep in mind that you also need to make the patch to “top.php” as suggested in the main post above.
I can’'t help you other than that as only you would know where your files/graphics are.
Opssssss
I believe that i should change the link about my graphics images in “ajax-images”.
The new version has a different folders about icons set used.
Is it ok?
Because, at this time, I don’t have any icons in my ajax-dashboard: www.meteocarmignano.it
Alessandro
Alessandro,
You need to upload the “ajaxWDwx-settings.js” file to your server as you’ve included it in your “top.php”.
It’s not there at the moment. You need to make all the changes in this file.
HERE’S YOUR ICON SETUP: (I think it’s this)// 1: NWS icons (55x58) wxIconSet1 = {src : imgDir+"#PIC#.jpg" // where #PIC# = picname from table in useName ,width : 55 ,height: 58 ,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" // eg. "border: 2px solid silver" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] ,useName: 1 // must be 1 for this icon set ... NWS icon nameing convention ... see ajax_getIconName1()) };
Do not delete the #PIC" part as that later gets replaced by a icon name depending on the current condition icon required.
and set this to:wxIconSet = wxIconSet1; // choose from an icon set above that you want to use.
You need to upload the "ajaxWDwx-settings.js" file to your server as you've included it in your "top.php". It's not there at the moment. You need to make all the changes in this file.
I’ve just done.
I’ve set like this “var wxIconSet = wxIconSet1” but i’ve all images in “ajax-images/”.
Unfortunately, there isn’t any choise for that.
Do you believe that i come back to the previously version?
Alessandro
Have you done the changes as I’ve posted above?
yes, i have.
Nope, I cant see them in either of the 2 files.
Maybe your server is caching somewhere.
Remember to make the changes to “ajaxWDws-settings.js” only as you have included it in your “top.php” file.
Allesandro and propably everybody else, here is your setup for ajaxWDwx-settings.js:
// 1: NWS icons (55x58)wxIconSet1 = {src : imgDir+"#PIC#.jpg" // where #PIC# will be replaced by picname from table in ajax_getIconName1() function ,width : 55 ,height: 58 ,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" // eg. "border: 2px solid silver" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] ,useName: 1 // must be 1 for this icon set ... NWS icon nameing convention ... see ajax_getIconName1()) };
// WIND ROSE: optional settings for the Wind Rose graphicwrImg = {src : imgDir+"wr-#LANG##DIR#.gif" // where #DIR# will = wind dir (e.g. NNW), #LANG# = wrImg.lang ,lang : "" // with trailing dash (e.g. "nl-" will result in graphic name: "./ajax-images/wind/wr-nl-SSE.gif") ,calm : "calm" // substitution for #DIR# (e.g "wr-calm.gif") ... specify "" if not to be shown or not available ,width : 58,height: 58,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] };
Don’t despair … once you’ve sorted this out you’ll never have to do it again.
Just downloaded this today, will try to implement this sometime this coming weekend.
Could you add the below:
//--- begin VPLEAF -------------------------------------------------------------
VPleaf = clientraw[156];
set_ajax_obs("ajaxVPleaf",VPleaf);
//--- end VPLEAF ------- -------------------------------------------------------
If its possible, could the Wind Speed and Wind Direction be separate? During the Winter months Ice buildup freezes either or both gauges here. I’ve attached what I’m currently using here, I just comment/uncomment a few lines for when gauges are frozen. And then upload it until the gauges thaw out.
Lines I modified for Ice, Wind Speed, and Wind Direction:
97-98, 110-111, 791-813
ajaxWDwx_js.txt (42.8 KB)
Hi Zalmor,
No problem, I’ll make the changes and add those tags for you.
Everybody just hang ten … I’m busy simplifying the external setup at the moment.
Great, thanks.
The VPleaf only shows up on my weather page when its not zero here.
Hi Rainer,
thanks for your support, now it works fine!
I’ve some questions for you
Are you ready?? :lol:
How is it and when should you implement it in the future?
// D: Dynamic generated icon set (170x127) ... NOT IMPLEMENTED
// ... you'll need: http://www.bashewa.com/download-dynamic-icon.php
wxIconSetD =
{src : "./dynamic-icon.php" // path and script for dynamic conditions image (optional)
,width : 170 ,height: 127 ,hspace: 0 ,vspace: 0 ,border: 0
,style : "border: 2px solid silver;"
,align : ""
,useName: 9 // must be 9 for generating dynamic icons
// If we had a uniform icon nameing convention the above would not be necessary.
Other question: why the images about “moon” and “Fire Risk” shows ok in my ajax-dashboard although the settings in ajaxWDwx-settings.js are wrong?
How to use this setting below? Because, actually, my webcam image works in the nightime too.
// WEBCAM IMAGE: optional setting for the webcam graphic
// tag: "ajaxwebcamimg"
// e.g. picture name: "./ajax-images/webcam/snap00.jpg"
webcamUpdate = 5; // Webcam update interval in minutes (set to 0 for no updates i.e. visitor must reload page for updates)
swapIconWithWebcam = false; // swap current conditions icon (tag "ajaxconditionicon2") with webcam image during day and night unless useCamAtNight=false;
useCamAtNight = true; // use current conditions icon at night time instead of webcam image
delayDayNight = 15; // day starts given minutes before sunrise and night starts given min after sunset - for night icon switch
webcamImg =
{src : imgDir+"webcam/snap00.jpg" // full path and image name of your current webcam picture
,srcNgt: imgDir+"webcam/snap00.jpg" // full path and image name of your current nightcam picture (after/before "delayDayNight")
,align : ""
Last question: In your version of ajaxWDwx.js severals value aren’t translation. How to fix it? (Look the attachment)
Last observation :lol:: The last version of ajaxWDwx.js is a bit more slow respecting the previously version 3.00.
Alessandro
NEW RELEASE v9.06
Version 9.06 - 12-Jan-2010Fixed...... problem with incorrect language translations. Added...... modified "language-??.js" files to installation zip. Added...... tag "ajaxVPleaf" ... VP leaf wetness Added...... alert to your visitors if you have Weather Station problems. Simpilfied. the setup in the external settings file "ajaxWDwx-settings.js".
Zalmor - Michael:
I have added the Leaf Wetness tag.
I see what your problem is with the instuments freezing up …
I have added a section to the Setup to address this issue …
See “WxStation” variable in the Setup where you can report Weather Station problems to your visitors.
i_fiorentino - Alessandro
The “Dynamic Icon” is a future development which I’m making provision for so long.
If you only have one Webcam you can specify the same image for both sources in the setup.
The translation problem has been fixed … I also suggest you load the modified “language-??.js” file which I have included in the latest release.
The new script is enormous and takes time to download …
I suggest you implement the External Setup script with the packed version of ajaxWDwx.js script … see note on [color=blue]page 1[/color].
Also the script no longer supports ajaxLoaderInBody i.e. …
you need to remove all of those in your scripts.
Also the script can only start updating once your entire page has been loaded.
PS: Once you have uploaded the script make sure to hit CTRL-F5 otherwise your browser will use your old cached version.
Thanks Rainer,
i’ll try it tonight… (Italy time )
Alessandro
Hey, check this out
I've cut my "ajaxWDwx-settings.js" file down to just a few lines: [[color=blue]ajaxWDwx-settings-bws.js[/color]](http://www.bashewa.com/ajaxWDwx-settings-bws.js) ....... and I've implemented the packed version of "ajaxWDwx.js": [[color=blue]ajaxWDwx-packed.js[/color]](http://www.bashewa.com/ajaxWDwx-packed.js)
I’ve included my version of the cut down setup script in the latest release.
Notes can also be found in [color=blue]ajaxWDwx-settings.js[/color] on how to do this.
PS: Thanks everybody that took the plunge earlier on and for all the feedback that you’ve given me.
It’s helped me tremendously in getting the script to what it’s now … simple, robust and no more hassle when upgrading to new versions.
I am trying to install this I have most of it working but for some reason my wind speed is in Km/h when I have changed all the settings ( well obviously I’ve missed one somewhere) to mph.
Also my cloud height graphic was showing before the change to the new ajaxWDwx file and initially on the change over but it has dissapeared now.
Phil
Hi Rainer
I always try to keep up with changes, but the transition from version 9.05 to 9.06 failed.
Despite the careful changes step by step I spoiled anything
My party, right after the refresh goes to the “updates paused”
where he made a mistake?
I admit that due to poor knowledge of English, not all understand.
I do not know what to do with this, in my case:
For static field that don't have an "ajaxtag" you need to add one of the
following classes to your fields:
<span class="convTemp">82.7°F</span> ...for temp
<span class="convWind"> 2.7 mph</span> ...for wind
<span class="convBaro">30.30 inHg</span> ...for temp
<span class="convRain"> 1.04 in</span> ...for rain
<span class="convSnow"> 12.4 in</span> ...for snow
<span class="convAlti"> 2793 ft</span> ...for altitude
<span class="convDist"> 15 miles</span> ...for distance
NOTE: the value in the span must include the units-of-measure for them be converted.
You'll also need the modified "thermometer.php" script that supports UOM switching.
Get it here: http://discourse.weather-watch.com/t/44293
although I understand that this is the effect of changes units.
But mainly I want to restore the automatic refreshing of data on my index page
thanks
andretti
edit:
I noticed something that may identify the error.
If the settings file (ajaxWDwx-settings.js) is:
, maxupdates: 36
the word “updated” blinks a short moment and update time is paused.
When I changed:
, maxupdates: 360
the word “updated” winks much longer than in the previous case.
I do not know where this takes but I think it matters.
