Version 9.05 released.
It’s now possible to have an external settings file which
should make upgrading to new versions easier.
A packed version of ajaxWDwx.js i.e ajaxWDwx-packed.js is also included in the latest release.
If you use the packed version you’ll need to use ajaxWDwx-settings.js as well.
Also an ALERT has been added if the “clientraw.txt” file can not be found.
See the 1st post above for more modifications and additions.
I guess this would just require replacing the currently used True’s js with yours, and after making the required settings adjustmnts, I would just have to reallign my own customizations that I made to the old js.
Congratulations Rainer!! This is a major leap forward in capability of the ajaxWDwx.js script – thank you!!
I like your suggestion on version-number ranges, so I’ll stick to the 2.xx range for mine. Would you allow me to bundle your latest version with the 5 template sets? I’d be pleased to do so
I’ve tested this script on my end for the last 6-8 months and it works fine on my end.
However I don’t know if there’s going to be any hiccups with the script since I only
released it to the community this morning.
I guess I will have to wait until some more people take the plunge.
Forgot to say:
Please download the latest version … I’ve added some more documentation to the script.
Hi Rainer,
could you explain me how to use new version of ajaxWDwx.js?
I’ve installed it but it seems to change nothing in my site.
I’ve seen that the new version has a lot of customization but i don’t know how to use some/all of these.
Should i upload the ajaxWDwx-settings.js too?
Many thanks,
Yes, I suggest you use “ajaxWDwx-settings.js” for your setup and then upload it to your server.
This will ensure that you won’t have to make changes to it again for the next upgrade.
However keep in mind that you also need to make the patch to “top.php” as suggested in the main post above.
I can’'t help you other than that as only you would know where your files/graphics are.
Opssssss
I believe that i should change the link about my graphics images in “ajax-images”.
The new version has a different folders about icons set used.
Is it ok?
Because, at this time, I don’t have any icons in my ajax-dashboard: www.meteocarmignano.it
Alessandro,
You need to upload the “ajaxWDwx-settings.js” file to your server as you’ve included it in your “top.php”.
It’s not there at the moment. You need to make all the changes in this file.
HERE’S YOUR ICON SETUP: (I think it’s this)// 1: NWS icons (55x58) wxIconSet1 = {src : imgDir+"#PIC#.jpg" // where #PIC# = picname from table in useName ,width : 55 ,height: 58 ,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" // eg. "border: 2px solid silver" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] ,useName: 1 // must be 1 for this icon set ... NWS icon nameing convention ... see ajax_getIconName1()) }; Do not delete the #PIC" part as that later gets replaced by a icon name depending on the current condition icon required.
and set this to:wxIconSet = wxIconSet1; // choose from an icon set above that you want to use.
You need to upload the "ajaxWDwx-settings.js" file to your server as you've included it in your "top.php".
It's not there at the moment. You need to make all the changes in this file.
I’ve just done.
I’ve set like this “var wxIconSet = wxIconSet1” but i’ve all images in “ajax-images/”.
Unfortunately, there isn’t any choise for that.
Do you believe that i come back to the previously version?
Allesandro and propably everybody else, here is your setup for ajaxWDwx-settings.js:
// 1: NWS icons (55x58)wxIconSet1 = {src : imgDir+"#PIC#.jpg" // where #PIC# will be replaced by picname from table in ajax_getIconName1() function ,width : 55 ,height: 58 ,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" // eg. "border: 2px solid silver" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] ,useName: 1 // must be 1 for this icon set ... NWS icon nameing convention ... see ajax_getIconName1()) };
// WIND ROSE: optional settings for the Wind Rose graphicwrImg = {src : imgDir+"wr-#LANG##DIR#.gif" // where #DIR# will = wind dir (e.g. NNW), #LANG# = wrImg.lang ,lang : "" // with trailing dash (e.g. "nl-" will result in graphic name: "./ajax-images/wind/wr-nl-SSE.gif") ,calm : "calm" // substitution for #DIR# (e.g "wr-calm.gif") ... specify "" if not to be shown or not available ,width : 58,height: 58,hspace: 0 ,vspace: 0 ,border: 0 ,style : "" ,align : "" // [ left | right | top | bottom | middle | texttop | absbottom | absmiddle ] };
Don’t despair … once you’ve sorted this out you’ll never have to do it again.
Just downloaded this today, will try to implement this sometime this coming weekend.
Could you add the below:
//--- begin VPLEAF -------------------------------------------------------------
VPleaf = clientraw[156];
set_ajax_obs("ajaxVPleaf",VPleaf);
//--- end VPLEAF ------- -------------------------------------------------------
If its possible, could the Wind Speed and Wind Direction be separate? During the Winter months Ice buildup freezes either or both gauges here. I’ve attached what I’m currently using here, I just comment/uncomment a few lines for when gauges are frozen. And then upload it until the gauges thaw out.
Lines I modified for Ice, Wind Speed, and Wind Direction:
97-98, 110-111, 791-813
