If you need something to use right now, you can use my web page below until curly gets his script developed. It will accept zone, county codes, and marine zones. Just change the last six characters after cozone=. The letters need to be all upper case i.e. CAZ508, CAC001. The results are cached for 5 minutes after which, you only need to reload the page.
Also, if you want to display the whole state, you can use this one, Just change the last two characters (state abbreviation) after state= which can be upper or lower case.
This is one of three projects that I have going on at the moment and havenāt had much time to spend on it.
Should be able to get back on it next week.
I have questions about getting started with AtomFeed that I havenāt been able to scour out. How is the AtomArray.php file created?
I followed the included instructions , creating an atomalerts folder, placing the included files in the proper places, setting up the vbs file in Taskmanager, and editing the AtomFeed-config.php. I then call up http://patricksweeneydds.com/atomalerts/AtomFeed.php, but there are a plethora of errors.
I created a blank AtomArray.php file and uploaded it to the root folder, but that didnāt help.
Am I biting off more than I can chew?
Iāve enclosed txt files of php files and a view of the atomalerts folder.
Thanks in advance for any clues.
Iām getting close.
There are txt files in my atomalerts/work folder now(Atom-CAZ019.txt and Atom-CAZ062.txt),
but still not showing up on my website.
When opening AtomFeed.php, there is only one error message now:
Warning: copy(ā¦/AtomArray.php) [function.copy]: failed to open stream: Permission denied in /virtual/users/e14790-15223/web/atomalerts/AtomFeed.php on line 1304
Copying work file to array file failed. Check file permissions if this persists
Here is my AtomStatus.txt
[b]
[/b]
Iām not sure how to get the work file to the array.
Warning: copy(../AtomArray.php) [function.copy]: failed to open stream: Permission denied in /virtual/users/e14790-15223/web/atomalerts/AtomFeed.php on line 1304
A file permission level is not allowing the script to copy a file to another folder.
The file is named AtomArray.php and itās location would be in your web folder.
Since the AtomFeed script is writng the updates to the work folder, I suspect the AtomArray.php file needs the permission level bumped up.
The text files in the work folder are updating like they should but the final AtomFeed data output file, AtomArray.php, isnāt getting updated.
NWS is going through a ruff spot again I too am getting the same error Half the time my web page has it correct and other times it says that NWS is having problems
It only does two zones per county when comparing the two for differences.
The alert messages are letting you know that those added zones donāt have a county to compare with.
You can get around this by not using the HIC003 array and having all zones listed separately.
"HIZ005" => "Oahu South Shore", // Priority zone listed first
"HIC003" => "Honolulu",
"HIZ006" => "Waianae Coast",
"HIZ007" => "Oahu North Shore",
"HIZ008" => "Oahu Koolau",
"HIZ009" => "Olomana",
"HIZ010" => "Central Oahu",
"HIZ011" => "Waianae Mountains"
