That extra array is for the county code to zone code conversion.
When entering a county code for the conversion, one zone code gets entered in the array (‘a’) unless that county is split into two zones. Only when a county is split into two zones, the second zone goes in ‘b’.
This line is correct
"WAC033" => array(1 => "WAC033",'a' => "WAZ505"), // COUNTY CODE => COUNTY CODE => ZONE CODE
You will need to delete this line
"WAZ033" => array(1 => "WAC033",'a' => "WAZ505",'b' => "WAZ505"), // COUNTY CODE => COUNTY CODE => ZONE CODE => ZONE CODE
When you have an array like this, set $use_conversion to true.
If you do not have that type of an array, set $use_conversion to false.
This is what i have…WAZ505 is my primary zone and WAC033 is my primary county. I got the other warning not showing now, which is what i wanted. is there a way for it to show " no warnings/advisories for a zone/location"? if there are no warnings?
$Code_Location = array(
"WAZ505" => "Snoqualmie,Wa", // Snoqualmie Wa - priority zone listed first
"WAZ508" => "Seattle Metropolitan Area, WA", // Seattle
"WAZ509" => "Tacoma Area, WA", // Tacoma
"WAZ519" => "West Slopes Central Cascades and Passes, WA", //
"WAC061" => "Snohomish County, WA", // Snohomish County, WA
"WAC037" => "Kittitas County, WA", // Kittitas County, WA
"WAC053" => "Pierce County, WA" // Pierce County, WA
Yes it should be showing a non alert message in the box.
I will need to duplicate your settings and see what is going on.
The problem that I have now is my internet service is down so I can’t get your county and zone alerts. #-o
I have a question about the last update statement…I’m using a vbs script in XP, should I expect to see that time change every 10 minutes (which is my update rate) or is this the time last updated by NOAA.
I would think the time should update every 10 minutes but that’s not my case.
I cant get the box size smaller to fit on my narrow page
Its showing a different zone than mine (NYZ037) on the main page.
Trying to get it to just show my zone
Here’s my settings:
$create_box = true; // true=create a box <div><table> false= no box created, just alert messages
$aBox_Width = '450'; // width of box examples - aBox_Width = '80%'; aBox_Width = '850px'; or smallest box aBox_Width = '';
$link2details = true; // true=link to full detail page false=link to summary page
$local_alerts = true; // true=show primary location false=show all locations
// also when set to true, all alerts are displayed for the local location
// regardless if limit_topAlerts is set to true
$limit_topAlerts = false; // true=display highest ranked alert for each code
// false=display all alerts for each code
$always_show = true; // true=display message if no alerts false=display message only when alert is active
$limit_NoAlerts = true; // true=show 1 'no alert' message if always_show=true
// false=show 'no alert' message for each code if always_show=true
// *only if local_alerts=false
$line_break = false; // true=one alert per line if aBox_Width is used false=fit multiple alerts on each line
// *if line_break=false AND aBox_Width has a value, icons are removed
$aBox_Color = '#FFEEBB'; // background color of the alert box if create_box=true examples '#FFF' '#FFEEBB' 'white'
$aBox_Border = '1'; // border size of alert box 0=no outline if create_box=true
$aBox_Icon = true; // true=show icons in alert box false=no icons in the alert box if create_box=true
