This new version replaces the previous version.
Recommendations by forum members, changes at the NWS, and issues over the past several months are addressed in this revised program.
The AtomFeed program now consists of three files that makes it more efficient in downloading data, handling errors, and using county codes along with zone codes.
As a side note, since this is going into another folder, do not delete the old AtomFeed.php file in your main folder until you test out the new one. You can always revert back to the old one if there are any issues.
I got it working, Thank you again Curly for all of your hard work.
One question… in the atomfeed-config file i have this for now…
"WAZ505" => "Snoqualmie,Wa", // Snoqualmie Wa - priority zone listed first
"WAC033" => array(1 => "WAC033",'a' => "WAZ505"), // COUNTY CODE => COUNTY CODE => ZONE CODE
"WAZ033" => array(1 => "WAC033",'a' => "WAZ505",'b' => "WAZ505"), // COUNTY CODE => COUNTY CODE => ZONE CODE => ZONE CODE
"MDZ006" => "No.Balt.Co.", // N Baltimore
"MDZ011" => "So.Balt.Co." // S Baltimore
In the old one i have this…
$ZoneLocation = array(
"WAZ505" => "East Puget Sound Lowlands, WA ",
"WAZ007" => "Seattle Metropolitan Area, WA ",
"WAZ507" => "Everett, Vicinity, WA ",
"WAZ509" => "Tacoma Area, WA ",
"WAZ519" => "West Slopes Central Cascades and Passes, WA ",
"WAC033" => "King County, WA",
"WAC061" => "Snohomish County, WA",
"WAC037" => "Kittitas County, WA",
"WAC053" => "Pierce County, WA"
My main zone is WAZ505 and my main county is WAC033… How would i type this into the new one? Thanks.
That extra array is for the county code to zone code conversion.
When entering a county code for the conversion, one zone code gets entered in the array (‘a’) unless that county is split into two zones. Only when a county is split into two zones, the second zone goes in ‘b’.
This line is correct
You will need to delete this line
When you have an array like this, set $use_conversion to true.
If you do not have that type of an array, set $use_conversion to false.
This is what i have…WAZ505 is my primary zone and WAC033 is my primary county. I got the other warning not showing now, which is what i wanted. is there a way for it to show " no warnings/advisories for a zone/location"? if there are no warnings?
$Code_Location = array(
"WAZ508" => "Seattle Metropolitan Area, WA", // Seattle
"WAZ509" => "Tacoma Area, WA", // Tacoma
"WAZ519" => "West Slopes Central Cascades and Passes, WA", //
"WAC061" => "Snohomish County, WA", // Snohomish County, WA
"WAC037" => "Kittitas County, WA", // Kittitas County, WA
"WAC053" => "Pierce County, WA" // Pierce County, WA
Yes it should be showing a non alert message in the box.
I will need to duplicate your settings and see what is going on.
The problem that I have now is my internet service is down so I can’t get your county and zone alerts. #-o
I have a question about the last update statement…I’m using a vbs script in XP, should I expect to see that time change every 10 minutes (which is my update rate) or is this the time last updated by NOAA.
I would think the time should update every 10 minutes but that’s not my case.
I cant get the box size smaller to fit on my narrow page
Its showing a different zone than mine (NYZ037) on the main page.
Trying to get it to just show my zone
Here’s my settings:
$create_box = true; // true=create a box <div><table> false= no box created, just alert messages
$aBox_Width = '450'; // width of box examples - aBox_Width = '80%'; aBox_Width = '850px'; or smallest box aBox_Width = '';
$link2details = true; // true=link to full detail page false=link to summary page
$local_alerts = true; // true=show primary location false=show all locations
// also when set to true, all alerts are displayed for the local location
// regardless if limit_topAlerts is set to true
$limit_topAlerts = false; // true=display highest ranked alert for each code
// false=display all alerts for each code
$always_show = true; // true=display message if no alerts false=display message only when alert is active
$limit_NoAlerts = true; // true=show 1 'no alert' message if always_show=true
// false=show 'no alert' message for each code if always_show=true
// *only if local_alerts=false
$line_break = false; // true=one alert per line if aBox_Width is used false=fit multiple alerts on each line
// *if line_break=false AND aBox_Width has a value, icons are removed
$aBox_Color = '#FFEEBB'; // background color of the alert box if create_box=true examples '#FFF' '#FFEEBB' 'white'
$aBox_Border = '1'; // border size of alert box 0=no outline if create_box=true
$aBox_Icon = true; // true=show icons in alert box false=no icons in the alert box if create_box=true
