Tom - at the bottom progress bar, there is space above for additional info if it is possible to make - such as indication tick boxes if data downloaded ok, a single letter for eg Metar = M [/] F[/] S[/] G1 [/] Ga [/] R [/] F [ ] M [ ] etc if you can detect whether there is a valid time stamp on the data, then it may be OK.
Can checks be performed so that when we do a manual run, then we can check the validity of data to some extent, or whether any existed - ie [X] if none existed or was bad timestamp… and empty if not selected.
Hopefully this will indicate either a check box issue or bad data or no data existed and would give us an understanding and a measure of fault diagnosis.
Graeme
NZ
