Author Topic: Virtual VP: read from USB datalogger  (Read 5257 times)
Offline thoko
« on: December 10, 2009, 09:24:21 AM »
I want to use Virtual VP as an intermediary between my Davis datalogger (USB) and my weatherprograms.
Virtual VP requires to receive data from the datalogger through a virtual COM-port.
How can I make the USB-port deliver data to a virtual COM-port?
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
    • Juneau County Weather
Re: Virtual VP: read from USB datalogger
« Reply #1 on: December 10, 2009, 11:08:25 AM »
That is all done for you.  Just follow the installation instructions and you should be good.
- Jim
Forum Search and Google can be your best friends
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #2 on: December 10, 2009, 06:06:41 PM »
make sure to not have the usb data logger set to USBExpress mode
Offline thoko
« Reply #3 on: December 11, 2009, 04:48:03 PM »
To Jim
Where can I find the information in which installation instructions?
Offline jmcmurry
  • Jim McMurry
  • Mauston, WI, USA
« Reply #4 on: December 11, 2009, 08:39:39 PM »
All of the documentation is available on the download page of Steve's site http://softwx.com/weather/virtualvp.html.
- Jim
Offline thoko
« Reply #5 on: December 12, 2009, 10:26:51 PM »
I have read the linked document and the Quick Start Guide to a level close to mightmare.
I have installed Virtual VP (now 1.2.3)
I have installed the N8VB drivers
I have an VP USB datalogger (Envoy)
I use XP sp3
WeatherLink can get data from the datalogger on COM1
Virtual Weather Station can get data from the datalogger on COM1
When I run VVP with COM3 I get the reply: Specified comport does not exist
When I run VVP with COM1 I get:
1. the "Reading archive data"-window opens for a few seconds with the subtext "Determine current archive position" and a blue bar 4-5 mm long.
2. After some 15-20 seconds the program stops. The log contains a few occurrences of the 2 warnings:
VpConsole No response after several retries for Wake Up Console and
VpConsole No response after several retries for Get Live Sensor Data
3. According to the "VP Console Connection" a few commands and bytes are sent to VP, but none received.
Where can I find the toggle for USBExpress?
On a forum I have seen reference to a Silicon Labs CP210X USB to UART Bridge. Does it have any relevance to the connection to the datalogger?
What can I do to open the communication to the datalogger?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #6 on: December 12, 2009, 11:09:57 PM »
what shows in weather link for the type of connection to the data logger?
what shows in device manager?
do you have a Silicon Labs CP210X USB to UART Bridge driver with an allocated com port number?
sounds like you do, and that is set to com 1?
Offline thoko
« Reply #7 on: December 13, 2009, 11:48:54 AM »
My WeatherLink (5.8.1) is set up with Communications Port = USB
My Device Manager shows LPT1 and COM1
As for CP210x: My WeatherLink folder has a file named "CP210xManufacturing.dll". I cannot see any other references to the driver. There is no trace of it in the Device Manager
In another topic http://www.weather-watch.com/smf/index.php/topic,39711.0.html I have seen indications that the USBExpress may be the real problem. Where can I find the setting of it?
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #8 on: December 13, 2009, 06:35:49 PM »
Quote
that means, to my knowledge, that you have set the data logger to USBexpress mode
you will need to set to serial mode in weather link and then run the convertor program
see the FAQ on how to do that
and then you should get a com port allocated to the usb to serial driver
