Author Topic: VirtualVP v.1.2.3 (64 bit support)  (Read 2908 times)
Offline SoftWx
  • Moderator
    • SoftWx
« on: December 07, 2009, 07:24:37 AM »
I have just put a new version of VirtualVP up on the website:
http://www.softwx.com/weather/virtualvp.html
It contains the following changes:
v. 1.2.3 Dec 6 2009
* Fixed bug that prevented operation on 64-bit versions of Windows.
* VirtualVP now uses the user data folder (Users\{username}\AppData\Local\SoftWx\VirtualVp)
   for all files to which data is written instead of the VirtualVP installation folder
   in order to function better on Vista and Windows 7 computers.
* Made changes so that VirtualVP only needs to be run as administrator once to to enable
   the initial 30 day trial, and when the registration code is entered. The rest of
   the time, VirtualVP can be run in normal user accounts without administrator
   privileges.
* Added pictorial instructions for installation and configuration of VirtualVP and weather
   programs that connect through it, and also for setting up a virtual serial port
   driver on 64-bit Windows 7.
* Removed option for mirroring archive data to disk. VirtualVP will now always mirror to disk.
Although VirtualVP does not have an issue now with 64 bit Windows, the signing issue with freeware drivers (like the virtual serial port drivers) still exists. There is a workaround that allows com0com to work, which is detailed in the 64 bit help pdf file I have on the website. Since most weather programs now support tcp/ip connections because of the WeatherLinkIP data logger, if you can connect all your weather programs to VirtualVP via tcp/ip, then you don't need a virtual serial port driver.
The new pdf help guides are examples of where I am headed with documentation; very little verbage, and lots of screenshots.
Steve
SoftWx
Offline The PIT
  • Sheffield South Yorks UK
    • Sheffieldweather
Re: VirtualVP v.1.2.3 (64 bit support)
« Reply #1 on: December 07, 2009, 07:57:37 PM »
I've got a license for 1.1.4 version can i use this on the latest build of VPP???
Location Sunny Sheffield South Yorkshire UK.
Weather cam and Web page at Sheffield Weather Page
PDA Web Page at PDA Link only
Offline jwwd
  • WML testers
  • Silkeborg, Denmark (56:10:58 N-09:30:26 E) - Elevation 75,35 meters
    • Weather at Silkeborg, Denmark
« Reply #2 on: December 07, 2009, 09:50:13 PM »
Hi Steve
Thanks for the update - I got it working with your excellent guides.
Henrik
Offline SoftWx
  • Moderator
    • SoftWx
« Reply #3 on: December 08, 2009, 02:10:44 AM »
Yes, registration from an earlier version on the same computer should get picked up automatically. If you change to a new computer, you can also enter you old serial number and key into the current version and it will accept them.
Steve
SoftWx
