Author Topic: AAG 1 Wire Humidity Sensor  (Read 1397 times)
Offline solarwarp
  • San Antonio, Texas
« on: May 17, 2004, 03:00:58 AM »
I just bought a AAG Humidity Sensor to add to my 1 Wire Weather Station.  I installed it outside in a home made pagoda and hooked up into the network.
Weather Display 1 Wire set-up page read the ROM ID, I have checked Extra Humidity sensor for main temperature.  Not certain if the temperature is being properly read and displayed nor do I see the Humidity being displayed.
What did I not do to show Humidity and temp from the Humidity sensor.
TIA
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: May 17, 2004, 03:41:52 AM »
have you copied the ROM ID into the humidity rom ID box?
and then click on save/reset
then it should say found and allocated, for that humidity sensor
then restart wd
