Hello,
(Sorry for my English, it is about a translator)
Since the version 10.37p buid09 the 1 wire does not function, I am oblige to give to the version former so that functions.
Serge
Hello,
Serge
the fix in the latest update was for the 1 wire hum sensors not working with a 1 wire hub
do you have a 1 wire hub?
have you tried the very latest version update?
do you have a 1 wire hub? -----Yes
have you tried the very latest version update?----Yes
Since the version 10.37p buid09 the 1 wire does not function.
Serge
thats strange
as I have been working with a 1 wire hub user, and it was not working for humidity and now is
I have build 10 uploaded now so that you know you have the latest update
Windy,
I work with the version 10.37P build 06 that functions well.
After many tests with the new version this it does not function for humidit
Windy,
Afflicted with the version 10.37p build 10 that still does not function,
Serge
can you give more information on how you mean it does not work?
i.e what shows in the 1 wire setup?
what shows there if you set to log raw data for testing, in the setup, advanced/misc setup?
I have ordered a 1 wire hum sensor so can do some testing here
but the current version works well for another person with a 1 wire hub, so I am surprised it does not for you
(which is why I need more info)
Hi Brian and Serge
Both 1037P build 9 and build 10 are working fine here with no hub and 2 temp sensors and a humidity sensor on a HobbyBoard humidity board. I didn’t get the snow sensor hooked back up today, but hopefully tomorrow. BTW I’m using the LinkUSB adapter.
Cheers
MikeyM
Windy, Mickeym,
The station 1wire does not function with 1037P build 9 and build 10 epas with moisture safe for the sun.
I currently remain with the version 1037P build 6.
Thank you.
Serge
can you provide more info?
as others are not reporting a problem
HI Brian
After updating to Build 10 I started to get spikes on the Hobbyboard humidiy sensor. As you can see the spikes started shortly after 8 pm 11/22/2009 when I updated to Build 10. I don’t have a copy of Build 9 so I can’t roll back. My 1-wire setup uses the LinkUSB adapter with the HobbyBoard power injector, Hobbyboard Humidity board with 2 temp sensors and no hub.
Hope this helps.
Cheers
MikeyM
Windy,
Herewith information:
Version 10.37P build 06 that functions
**Searching for Weather station sensors
**Searching for Weather station sensors part 2
Hub i-button found: F300000004BA201F
#1 Hub i-button allocated ID F300000004BA201F
Hub i-button found: 9900000004C06A1F
#2 Hub i-button allocated ID 9900000004C06A1F
Hub i-button found: F300000004BB391F
#3 Hub i-button allocated ID F300000004BB391F
**Searching on main HUB A port
Leaf i-button found, ID 300000116F3D3D30
Leaf i-button allocated to, ID 300000116F3D3D30
Humidity i-button found, ID 5A0000009E0BE926
**Searching on aux HUB A port
**Searching on main HUB B port
Leaf i-button found, ID F80000116F38FA30
Humidity i-button found, ID 1A000000B64AA526
5th Humidity i-button allocated to, ID 1A000000B64AA526
Temperature i-button found, ID D900080154B42A10
**Searching on aux HUB B port
**Searching on main HUB C port
**Searching on aux HUB C port
Snow sensor temperature 6.4
About to do the recallesquared
flag returned from recallesquared 1
raw solar reading =0.0000
Snow VDD 5.06000
Snow sensor temperature 6.3
Snow VDD 5.07000
Snow VDD 5.06000
Wmr100 forecast icon raw =0
version 10.37P build 10 does not function
***#1 Hub i-button allocated ID F300000004BA201F
***#2 Hub i-button allocated ID 9900000004C06A1F
***#3 Hub i-button allocated ID F300000004BB391F
***5th Humidity i-button allocated to, ID 1A000000B64AA526
***Leaf i-button allocated to, ID 300000116F3D3D30
Doing checking of time zone calculation
Daylight saving not in use
Adding aprs data to the missed data file 15:39
missed aprs hour normal 17
missed aprs hour from logger 15
missed aprs hour difference -1
missed aprs new hour /day/normalday 14 23 23
missed aprs new time 11/23/2009 15:39:00
flag returned from recallesquared solar1
Thank you.
Serge
you had not said that you have a leaf wetness sensor in use (used for snow measurements)
i had posted that I am still to work on getting that to work correctly with the 1 wire hub
I will work on that today
Mikeym, this station is running completly on 1 wire sensors for all the readings (ADS direction and vortex windspeed)
via a hub
http://www.shellypark.co.nz/
and there is no humidity spikes
not sure why you are getting them
but not having a hub must be the clue
when I get my hum sensor here I will do some testing without a hub
Afflicted Windy, I do not dominate of all the language of Shakespeare , I will hold you with the current of operation at the time of the next remote loading.
Thank you.
Serge
try a new .zip update, ready now
is that the snow sensor was not working, or?
so that you know which version, its now build 11, .zip update, ready now
that update should work OK with the snow sensor again on a hub
Windy,
Not, that does not function with the version build 11.
Serge
please provide more information, like what shows in the 1 wire setup
just saying it does not work is of no help
Ok Windy, version build11
Leaf or soil i-button found, ID F80000116F38FA30
Leaf or soil i-button found, ID 300000116F3D3D30
19:57:54 23/11/09 0.2
******Searching on main HUB C port**** Leaf or soil i-button found, ID 300000116F3D3D30 ***Leaf i-button allocated to, ID 300000116F3D3D30
so it is finding the leaf sensor OK
but does not look like its reading it?
Humidity i-button found, ID 1A000000B64AA526 ***5th Humidity i-button allocated to, ID 1A000000B64AA526
this is your snow sensor, so that has been found and allocated OK too
but its not been read?
