I had an older version of WXSIM on trial for a while and was hoping to get the full version soon. I deleted the older version and downloaded the latest wxsimdem file. When i try to run it wxsim opens ok, then I click on the “Import” then “start wxsimate”. WXSIMATE opens but I also get a box which opens saying “Optional program wxsimate not found”.
As wxsimate isin fact open I then click on “Download files” and it goes through the download routine. Once that is done and the “auto cull” starts I get an error message "could not find file “C:\wxsim\metar.lst” with the following details:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.IO.FileNotFoundException: Could not find file “C:\wxsim\metar.lst”.
File name: “C:\wxsim\metar.lst”
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream…ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.IO.File.Open(String path, FileMode mode)
at wxsimate.Form1.readcty()
at wxsimate.Form1.downloader()
at wxsimate.Form1.downld_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************
mscorlib
Assembly Version: 1.0.5000.0
Win32 Version: 1.1.4322.2443
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dllwxsimate
Assembly Version: 1.0.3542.22852
Win32 Version: 1.0.3542.22852
CodeBase: file:///C:/wxsim/wxsimate.exeSystem.Windows.Forms
Win32 Version: 1.1.4322.2032
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dllSystem
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dllSystem.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dllMicrosoft.VisualBasic
Assembly Version: 7.0.5000.0
Win32 Version: 7.10.6001.4
CodeBase: file:///c:/windows/assembly/gac/microsoft.visualbasic/7.0.5000.0__b03f5f7f11d50a3a/microsoft.visualbasic.dllSystem.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll************** JIT Debugging **************
To enable just in time (JIT) debugging, the config file for this
application or machine (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the machine
rather than being handled by this dialog.
If I then click “close” wxsimate closes I go to Import data and select the “wdata.txt” file but when I click "get data I get another error “runtime error 62 Input past end of file” I click on OK and the whole lot closes down.
I am hoping to get Wxsim for my birthday in a few weeks (if I can persuede the wife!!) but would like to see it working in the test version first. I am a complete novice at this stuff so have probably done something stupid, so any help gratefully recieved.
Phil
