Hello!
Im running my WD in client mode on PC2 and recive my weather data from my other PC1 connected to a WMR968 both latest WD and XP pro.
On PC2 I have a 1-wire network with usb adaptor, hub, solar sensor, and seven temp 18s20 in dasychain.
No problem getting the data from PC1 to PC2…but when I enable the 1-wire network under control panel → compots and settings-> dallas 1-wire the humidity stops working and stays steddy at the % value it was. I know that It has something to do with the solars sensor since It works when I disconnect it. I have tried every possibillity in the dallas 1-wire setup, so I have started to think this might be a bug? Any suggestions or knowledge in this matter?
Cheers!
Raze
