Amazing. Thanks. Just changed permissions on /web directory to 717 on my e-rice account and the graphics are displaying. Except for the Latest Mauna Loa Solar Image for some reason. Gotta figure that one out now… Getting closer!
Greg.
Greg.
Okay I get the basic idea of this info, but cant get my head around regional validity ie is it only of value if your in the states or could it be of value else where in the world.
Anyone have any ideas why all the graphics except the Mauna Loa Solar Image are displaying on my wxspace page???
Do you have the permissions set different on that file compared to the rest?
Warning: chmod() [function.chmod]: Operation not permitted in /virtual/users/e16314-17467/web/image-space-solar-disk.php
There is a setting to disable CHMOD in each image php file.
Works now - set the CHMOD option to “0” - worked like a charm - all the graphics are displaying now - Thanks!!
Also set the permissions for all files to 776 - not sure if that made a difference because only that one graphic would not display.
Appreciate the 411 -
Greg.
Got the script up and running after messing with some permissions, but now Im seeing another issue. What would stop the images from updating on their own? If i delete the images in FTP and refresh the page, they get updated, but they wont on their own. Any ideas? Thanks, Mark.
Version: 1.1 - 24-Oct-2009
See new page here:
http://www.642weather.com/weather/space-weather.php
Hi Mike,
i’ve a problem with the new version of your script.
The forecast about 3-day solar geophysical isn’t available.
Probabily Chmod problem?
Alessandro
Will this work with world mml template? ( I know it says USA template but thought I’d try it, any chance of making it available for world mml?) I have it installed but getting “error 003” where the images should be. I have changed permissions to 777 and set chmod to 0 to no avail.
http://www.weybourneweather.co.uk//wxspace.php
Phil
How often are the images updated? Today is the 24th and:
The 3 day forecast is for the 23rd
The solar wind is for the 22nd
The auroral map is for the 21st
The x-ray flux is up to the 22nd
I can’t see the others dates because they are too small.
What to do if you get Error 003 displayed in the images.
Description of the PHP error:
cannot write to file, you need to adjust the server permission settings.
Solution:
This is a PHP error telling you that your server is setup with too strict file permissions,
not every server is the same so it is not possible to give you one specific solution.
Try changing the folder permissions(CHMOD) to 755, 717, or on some servers 777.
Here is a tutorial on how to change folder permissions using your FTP program.
http://www.stadtaus.com/en/tutorials/chmod-ftp-file-permissions.php
If your host has PHP safe_mode = on, this will cause many PHP scripts to have permission problems and errors.
Ask your host to turn safe_mode off, safe_mode was determined to be a bad idea and will be removed from PHP6.
The 3 day forecast is updated every 3 days, the next update should be on the 26th.
My images are current as of today. Not sure what caused that but you should update to the latest version because I updated all the image files to a new improved version of my image handler script.
Mike,
I’ve added this great plugin to the plugins reference page for the WD/AJAX/PHP templates.
Thanks so much for generating this informative page/plugin.
Ken
BTW… to make it XHTML 1.0-Strict (like my site), I did three things:
1)changed the
Ken, in this new version I used
Version: 1.2 - 24-Oct-2009
I updated to the new version a few hours ago and the new sun images uploaded, but the old images did not update. Now after a few hours, the sun images are giving a “error:019” message. I changed all the file permissions as we discussed the other day.
error:019 means the image server was not online, it could not download the image from it.
I think the SOHO image server is down for scheduled maintenance.
http://sohowww.nascom.nasa.gov/
“External access to ESAC will be unavailable due to network maintenance on 24th October 2009 between 00:00 hrs and 05:00 hrs GMT.”
Thanks Mike for your script,
It running at http://www.meteocarmignano.it/wxspace.php
Alessandro
When viewing your page I get error 019 from the first two images
Duh saw your explanation later in the thread. Will update my page to the new version today
Hi All,
I updated my Space Weather page www.dwayneyamato.com/wx/wxspace.php it seems to be working except the the first two images have an error or 007 instead of 019 that I was seeing on Mike’s page. Is James Bond coming into the picture. :roll:
Thanks Mike for another great update.
–Stan Y.
Maui, Hawaii
