With the recent drastic and unseasonal wx patterns occurring, I decided to create a custom report w/ values for use in WXSIMs Refinement section. I “pre-load” these refinements for upcoming auto-runs. Just not sure if they’ll stick when the other data is imported for the auto-run.
I realize WXSIM imports the majority of the info, but wanted a 1-stop for the other data. It was driving me crazy going to multiple places to retrieve the data for the various forms. This is in it’s infancy and I plan on making a custom WD form, if possible.
Let me know what you think.
TO USE:
If you already have a customtext.txt file in use, rename this file to customtext1.txt before placing it in your local wd\webfiles dir.
In WD, GOTO “Setup/Logfiles”, turn switch on, under “CSV” Section select update interval.
To access the file, make a shortcut on desktop to webfiles\customtextout.txt (or customtext1out.txt).
customtext.txt (1.95 KB)
