Brian,
42004lg.txt ends at 23 58. WD did not create a 52004lg.txt for May. The Dailylog.txt is empty except for headers. there is the .csv versions of the logs. the NOAA reports Icon prduces an error “Data File Not found”.
The web noaa reports that were uploaded are in error as well. check them out here:
http://www.mauzeynet.com/newweather/images/dailyreport.htm
http://www.mauzeynet.com/newweather/images/dailynoaareport.htm
it should do…i am surprised…
hopefully is not a glitch i have introduced
maybe try restarting wd
Brian, I tried that a couple of times this morning at 05:00 with no result, But oddly, at exaclty 09:58 the log created itself and began logging while I was out doing my Yard chores.
humm
do you have midnight or 9am reset times set for the main av/extreme reset, under the units setup ?
good it finally woke up and corrected itself, lol
is the time hour bars on the graph better now too with 10.10t?
Midnight as per usual. Actual the hour bars are not good at all:
http://www.mauzeynet.com/newweather/images/mauzeynetgraph.gif
The Log looks perfect. Although the For some reason WD has tried to launch a second copy of itself a couple of times today (2)
http://www.mannheim-wetter.info/wetter/daten.gif
this persons graph looks good
maybe try a new 10.10t, as i did do a update of a small change?
but i also would try waiting maybe another 24 hours to see how it pans out too
Will do. I wonder why the April log ended at minute 58 and not 59? Did you see my daily and noaa reports. the daily report for april started with the 31st and ended with the 28th. 8O Too strange.
the started wtih the 31st is a bug i need to fix, and is because the log file most likely started with day 31 in it…check that…and try removing that data
also, the misisng 59 might be that new routine i put in…try inserting a line of data
why is the noaa report so important to people?
i very rarely check it
is it the HDD?
I don’t know why the NOAA report is so important, I think the fact that if a feature is present, and it is not right, than that casts doubt on data integrity. It is just human nature to see an error and not be able to live without that feature from that point on. :roll:
I did add the 59th minute to the april logfile.
Oh Well,
humm, ok…
yeah, its just the way the routine uses the data
the actual data will be ok
i notice that april av/ext web report had day 31
i guess i really need to sit down and fix things like that
but there are just so many other things in my life at the moment that are more important than a day appearing on a report when it shouldnt…
but i will have more time in another 4 weeks or so to fix things like
do you have the wdwatch in use?
(see under setup, general and misc)
Yes I do use WD Watch and that does pop up before launching a second copy of WD.
Last Friday using latest WD version when I came home from work I had three WD programs running. I never have used the watch program. Closed all three and it’s been fine since. I thought maybe someone was playing around with my computer.
jeff, i think i have a fix for the 12 graph hour line bars
uploading that as 10.10u now
it will be a few hours before its ready to download though
I have the same problem that WD will launch a second copy if itselves. I don’t use wdwatch…
very strange
i have never seen this happen
Brian, I downloaded 10.10v Beta and still seeing double hour lines, Although the data in the log apears to be right on.
Sorry,
humm
back to the drawing board
but i will get there in the end
