I am new to Weather Display Live, I previously used Weatherflash and VWS software on my website but have decided to try Weather Display. The message appearing states “check that your clientraw data files are in the location specified in the WDL configuration file and are not corrupted.”
I uploaded the folder ‘upload’ with all the files needed to my web directory and I have set up Weather display to send the clientraw files to that folder by /public_html/upload/
The web address for the page is www.weatherinaflash.com/upload/current.html
Does anybody know what I could be doing wrong?
Regards, Robb1978
For some reason your http://www.weatherinaflash.com/upload/clientraw.txt file is not complete, it should have 164 fields and it only has 108 (you can use the parser at http://www.tnetweather.com/wd-parser.php to check it, and the spec is http://www.tnetweather.com/nb-0100.php).
What version of WD are you running?
I am using version 10.30o. I have just parsed up the files and it stated that on the clientraw.txt array length does not match the number of records expected 168 and a similar statement for the other three. Its as though all the information is not there.
Robb1978
Are you using the realtime FTP to upload the files? If so you should have a yellow/red icon in the system tray (lower right corner of screen), if you click that it should open a window which will show what is happening when the files are uploaded. (Minimize don’t close that window when you are done.)
What OS?
I have sorted the problem, I set to and it started to upload properly.
Now I have the task of making it appear in a div or an iframe.
Regards Robb1978
www.weatherinaflash/upload/current.html
