* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * END OF MAIN SCRIPT* * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * function setmap(args)'set mproj nps''set mpvals 15 52 54 71''set lon -60 80''set lat 10 80''set mpdset hires'
Hi,you need to run the bat file at times 6,12,18,02 CET, otherwise you get that error msg, because it is trying to do the new forecast, but the data file is not ready on the server.I will try to workout the Italy rgion for you..EmsiWx
Error { code = 0; message = "extraction failed; not enough lat data in /tomcat_cache/gds/grads/dods/gfs_0p25/gfs20180528/gfs_0p25_18z.lat.output";};
Error { code = 0; message = "/gfs_0p25/gfs20180528/gfs_0p25_18z is not an available dataset";};
