Wow, I can actually answer this one because I’m nearby, and have seen a bit of the same thing!
I think it’s a cloud cover problem. We have this tropical depression thing that passed west of us, and the GFS (and probably NAM FOUS, too) have suggested lots of clouds, which WXSIM has believed. The cloud cover in the forecast is keeping temperatures down a lot, but in reality (at least here) the sun has popped out for maybe up to an hour at a time, which has kicked the temperatures well above the forecast values.
This is actually one of the outstanding issues in WXSIM, for which I don’t have a totally satisfactory solution. On average, the cloud cover forecasts are pretty good, but these breaks aren’t quite properly modeled in the program (though I do have a statistical variation incorporated, which helps some).
I do have some suggestions that should help:
(1) Make sure the ‘shower’ option on the Interrupt Planner form is checked. I probably had it checked by default in your customization, but make sure. This at least allows breaks between the rain, if not the clouds.
(2) The ‘Stop AM Rain’ refinement on the main (data entry) form. I’m not using it right now, but I probably should be. What it does is to limit shower activity to the afternoon and early evening, under the assumption that it’s convective and requires daytime heating to get going - even if external model data throws some in earlier or later. This will allow more warming through about 2 PM, and then the showers come along.
It’s interesting that here in Georgia (and probably other places) a forecast in summer of overcast skies in summer is rarely actually true, except with an east wind (“the wedge”). It’s almost like the temperature is obligated to make it into the 80’s F, and the sun will break through the clouds just to make sure!
One effect of this is that in a summer with a mix of sunny and mostly cloudy days, the forecast is almost perfect on average, but the cloudier days are forecast too cool and the sunny days just a bit too warm. I’m still looking for a way for WXSIM to “know” that the sun is bound to break out!
By the way, this problem may exists outside the southeastern U.S. as well. Any comments from elsewhere?
BTW - I think it’s a coincidence that you just got this problem with version 12.6. The weather pattern changed just about that time.
Tom
