Moon-tags
The moon tags are out of date. This is how they show on my webpage, normally they should be updated to the next date.
Nieuwe maan 22:42 UTC 20 maart 2004
Eerste kwartier 23:48 UTC 28 maart 2004
Laatste kwartier 03:47 UTC 12 april 2004
Volle maan 11:03 UTC 5 april 2004
Greetz,
Koen
humm, thats an old bug that i thought was squashed long ago
the date should be being updated every day…
i wonder why it is not for you…
Does it update with you every day? Are there several things I can try to make it work?
i just checked mine, and yes, it still has has some dates from the end of march…
hopefully it will change soon to show dates in the future!
(its out of my control, its all done with a component you see)
I found out why they aren’t (still) updated. The update begins after the next new moon, this month april 19th. The %newmoon%-tag shows the last new moon (march 20th), not the next. Could you add a tag which also indicates the next new moon? The moon/sun extra details shows them both too. If you have the time you may also add a tag for the moonphase in %.
Thanks!
Greetz,
Koen
%moonphase%
is actualy already able to be used, but i forgot to put in the owntemplate.txt file :slight_smile:
I am adding in %nextnewmoon% for the next update of wd
Ok, thanks Brian!
try a new 10.10o beta download now
(it should be available now)
for the addition of the nextnewmoon tag
I tried the latest version (oploaded around 2:00 am) but the tag is not recognised.
that must mean you still have an older verison, and not the new new beta version 10.10o
Ok, got the new version now. The tag works perfect. Thanks!!
Greetz,
Koen
