I’ve noticed something a little strange this morning with my AtomSummary page. I’ve added some zones outside of my area to test out the scripts. I have attached a screen shot of when there was two advisories/warnings for one zone (in this case Texas Oklahoma). Notice that there is a blue line at the top of each warning/advisory except the top one. Also, more important is a blue line through the short term forecast for Texas Oklahoma. Any ideas on where the problem is?
I believe the blue lines are just the underlining indicating that they are links. It sure does mess things up when you have two in the same area. You can modify the css to remove that with text-decoration:none; I believe.
I think the line height is spacing everything farther than what it should be. Before you adjust your CSS, do this first.
Open AtomSummary.php and find this line
You must of caught me after I re uploaded the AtomSummary.php and didn’t make the changes again. So where do you suggest that the css should be changed?
For those who are seeing the large space between the link and underline in the AtomSummary.php page, this can be easily fixed.
Open AtomSummary.php, find this and then delete it.
CronJob Title: Call this whatever you want so you can identify it. (You may have more than one cron during the life of your site)
Command: Not sure exactly what your host wants here but the file to cron would be the following: http://www.cwksr.com/AtomFeed.php
Frequency: Not sure of what choices you have here in the drop down box but you probably want to Fetch the Feed every 15 minutes, Everyday of the week, 24 hours a day.
Minute: See frequency above
I know this is not much help but it should move you in the right direction.
OK…I have it all set up (I think) the only item I can see that will not display is the “iconkey”…just gives me a blank page. I’m still searching for the cause
OK, I am kind of lost on this one also. I downloaded the files and finished the main settings including the zones. (Do I enter both the area and county zones?)
I am running an earlier version of the template modified so it is php. I would like the main warning on my index page and the full advisories on my advisory page. (wx4.php)
