You could run the Atomfeed from a crontab and set for how often you want it to check for updates. Say every 15 minutes.
AtomFeed.php needs to be called by a cron job every 15 minutes or so.
Some hosters don’t offer crons but Mike Challis has a program that uses the Window$ Task Scheduler to perform this action reliably.
http://www.642weather.com/weather/wxblog/php-scripts/scheduled-http-request-windows-task-scheduler/
Got It working…TY
Fixed a minor error in the AtomSummary.php that didn’t validate as strict.
Find this
<a href="#" style="color: black; font-size: 90%;" onClick="window.open('./images/iconkey.png', '','width=572,height=398')">Icon key</a>
Replace it with this
<a href="#" style="color: black; font-size: 90%;" onclick="window.open('./images/iconkey.png', '','width=572,height=398')">Icon key</a>
If you want the timezone displayed on the end of the time at “Last update:”
Find this
$update_time = " Last update: " . date ("F d Y g:i a",filemtime($file))." ";
$update_time = " Last update: " . date ("F d Y g:i a T",filemtime($file))." ";
Curly,
Added the timezone, my update time now displays:
From This:
Last Updated: July 18 2009 8:29 pm
To This:
Last Updated: July 18 2009 8:29 pm EDT
Michael
I’ve noticed something a little strange this morning with my AtomSummary page. I’ve added some zones outside of my area to test out the scripts. I have attached a screen shot of when there was two advisories/warnings for one zone (in this case Texas Oklahoma). Notice that there is a blue line at the top of each warning/advisory except the top one. Also, more important is a blue line through the short term forecast for Texas Oklahoma. Any ideas on where the problem is?
http://www.harpersferry-weather.com/AtomSummary.php
John
AtomSummary.zip (108 KB)
John,
I believe the blue lines are just the underlining indicating that they are links. It sure does mess things up when you have two in the same area. You can modify the css to remove that with text-decoration:none; I believe.
- Jim
John,
I think the line height is spacing everything farther than what it should be. Before you adjust your CSS, do this first.
Open AtomSummary.php and find this line
print '<span style="font-size: 120%; line-height: 2em"><b>'.$a[0][2].' - '. $a[0][0]. '</b></span>
Replace it with this line
print '<span style="font-size: 120%"><b>'.$a[0][2].' - '. $a[0][0]. '</b></span>
After you do that, then the css can be adjusted if needed.
That doesn’t seem to have done anything. Where do you suggest that I make adjustments to the decoration?
John
John,
Looks fine here using IE8.
Michael
I’m seeing this issue using FireFox 3.0.11. I did bring it up in Internet Explorer and it shows fine.
John
John,
That line-height is still in your page
<span style="font-size: 120%; line-height: 2em"><b>Clay Minnesota - MNZ003</b></span>
I don’t think changing the css will have any effect until line-height: 2em is removed.
You must of caught me after I re uploaded the AtomSummary.php and didn’t make the changes again. So where do you suggest that the css should be changed?
John
John,
Give me some time to figure this out. I’m at your site looking into it.
For those who are seeing the large space between the link and underline in the AtomSummary.php page, this can be easily fixed.
Open AtomSummary.php, find this and then delete it.
; vertical-align: top;
Curly
Chris,
Do you need to know what to place in your cron manager?
Michael
Indeed I do since this Cron stuff is all very new to me. Any and all help is appreciated!
CronJob Title: Call this whatever you want so you can identify it. (You may have more than one cron during the life of your site)
Command: Not sure exactly what your host wants here but the file to cron would be the following: http://www.cwksr.com/AtomFeed.php
Frequency: Not sure of what choices you have here in the drop down box but you probably want to Fetch the Feed every 15 minutes, Everyday of the week, 24 hours a day.
Minute: See frequency above
I know this is not much help but it should move you in the right direction.
Edit: if you use GoDaddy.com as a host (i think you do) I’ve read that the Command should be
curl http://www.cwksr.com/AtomFeed.php
OK…I have it all set up (I think) the only item I can see that will not display is the “iconkey”…just gives me a blank page. I’m still searching for the cause
