Beer’s on me Mike. Installing it now. Thank You!
Great App… Works like a charm Thanks Mike =D>
Have mine all installed both of them. But had to put into a seperate directory and let the owner be the only one able to read write and execute the files. So now if i type in the directory name those files are in comes up 403 error also had to place a seperate copy of the rss-top-warning-2009 in there also. as it would not allow writing to the directory when pulling from another. So now waiting for the 15 mins to run and see if the cron runs it, have to wait 6 hours for the other.
My scripts run in the same directory on my server, no problem.
Some servers are setup to be very strict about file permissions.
Some users have file permissions problems with the cache files:
Here are some tips:
(Do this only if you are having file permissions errors!)
Create the file in Notepad or similar text editor. The file can be empty.
adv-alert-email-XXXXX.txt (substitute XXXXX for your NOAA zone code in UPPER CASE)
rss-advisory-XXXXX.txt
Upload it to your server and CHMOD it to 666
You may continue to have problems if your server has “safe_mode on” or other restrictions on file create, file write functions.
In that case, find out if you can use your own php.ini to change PHP settings.
Please consult your web host tech support, or perhaps get another less restrictive web host!
nws-forecast-messenger & rss-weather-alerter work perfect with the way i had to set them, Just tested them now to make sure they where sending the data from the cron job. And sure enough the forecast was there and the weather alerter i had to set to test as there are none here now, and get my email on the phone for both.
Great job you guys do!
Dont see Special Weather Statements coming through to Advisory Alerter Mike.
I do see that in the beta feeds
Tony, I just loaded up the script with your zone and it worked.
If email is not sending, here is couple things to troubleshoot:
Correctly set the $email_address and $email_address_sent_from
By default, email is disabled. ( I guess I did this because you have to set your email address anyway and while there you should look at all the settings)
To enable email sending, set the change the setting $do_not_email = 1; to $do_not_email = 0;
The script will only send out an alert email one time when there is a change in alert status.
Hey everybody! What about this idea?
Currently, the script will only sends out an alert email one time when there is a change in alert status.
I might add a feature to resend the alerts every xx amount of hours.
This could be an option setting to turn on or off and set a time interval.
Sometimes in the winter I get a high wind warning that lasts for 3 days.
Using this proposed feature it could resend the alerts every 12 hours.
I use this feature ($flood_filter_enabled and $flood_filter_minutes) in my NWS Weather Forecast Messenger PHP Script
My cron actually calls that script every 15 minutes, but I set the $flood_filter_minutes to 355 minutes.
This allows the script to send a message approx every 6 hours. I think this feature would be great for this script also, I would set it to every 12 hours. also it would not send messages when there are no alerts.
Edit: Feature added in Version: 1.07 - 11-Jul-2009
I just had another special weather statement at 1:33pm issued Mike and it’s a no show on FB or Twitter or email
http://www.cnyweather.com/rss-weather-alerter.php
Here’s what I have.
// set to 1 to test the script's email function (it will send a test fake alert, be sure to set it back when done)
// set to 0 for normal operation
$test_email_advisory = 0;
// set to 1 to testing the script (will not send ANY emails!, be sure to set it back when done testing)
$do_not_email = 0;
// NOAA rss server where feeds come from
$RSS_URL = 'http://www.weather.gov/alerts-beta/wwaatmget.php?x=';
There can be many alerts at the same time, so it uses “Top Warning” code from my other script, it only recognizes the top most urgent warning.
Your current active top alert is “Severe Thunderstorm Watch”
No messages will be sent until the advisory status changes to something other than “Severe Thunderstorm Watch”.
This has a limitation if the alert is active for more than a desired message sending interval. I just explained in my last post, i think I will add a feature to resend current alerts every xx hours. I like the idea of every 12 hours.
ah I mis understood how it was working. Thanks!! 8)
Im sure my problem is host related. But can you take a look please…
http://www.snoqualmieweather.com/rss-weather-alerter.php
Ive added a .txt file called “adv-alert-message-WAZ505.txt” Set the permissions too 666 but the file is still empty. I installed this yesterday afternoon. Thanks.
I used the login from the last time I helped you. I just looked and your PHP server has safe_mode on.
That is the reason you continually have problems like this.
I wonder if you can access the php.ini to turn safe_mode off?
I cant find that file anywhere. I’ll open a ticket with them and ask If it can be turned off. Thanks for looking Mike.
Version: 1.07 - 11-Jul-2009 - fixed another bug where the email message had the zone title added twice.
- added feature setting: $message_resend_enabled to allow resending alert messages at pre-determined intervals
some areas can have an active alert like a “High Wind Warning” for more than a day or two.
This feature allows resending the active alert messages like every 12 hours or so
Great script again there. But a few questions:
- This is the type of twitter and phone text message it does: NWS issued: Severe Weather Statement - Cambria (Pennsylvania) for Cambria (Pennsylvania)
Is there a way to modify it in a easy way for us users to make changes to it to say to twitter something like:
NWS issued: Severe Weather Statement - For Cambria County (Pennsylvania)
this way it is not repeating after pa with cambira county again.
thanks!
What version is doing that double zone title? I thought I fixed that in version 1.07
My luck sheesh! let me grab 1.07 lol
Version: 1.06 - 10-Jul-2009
Ok 1.07 is up there now!
I’m not sure why but I cannot get it to work entirely correctly.
Of course, there’s nothing for weather now to give you an example but let me try to describe.
Yesterday for example, it was saying for the em the initial special weather advisory but would not have any other details. Ie:
Subject:
Message Body:
“Alert: Special Weather Statement”
Any thoughts? The advisory text only had “Special Weather Statement” and the rss file had all the info. My goal is to have a twitter with the advisory and pertinent advisory info
Cheers and thanks!
Mike
The script only alerts about the advisory title, it does not display the contents of the alert.
Twitters cannot be more than 140 characters. If I tried to parse the contents of the “Special Weather Statement”, it would not fit in a twitter anyway.
For this reason, my twitters have a URL on them, if they click on the URL they can see the full alert on my web site.
http://twitter.com/642weather
That is one of the drawbacks of twitter. The messages are so short #-o
I had a twitter alert this morning (there was a local thunderstorm):
NWS issued: Short Term Forecast for South Washington Coast (Washington) #fb #funbeach #weather http://642weather.com
If you need short URLs for the twitter message, you can use tinyurl.com or http://bit.ly/
