Seen that if i delete the txt file that it creates, then it works but doing a refresh on the page the error hits every time.
Like right now. My page just had it again. When I refresh it goes away. Then If i go back in 5 mins, it could be there again. The NWS has been having problems since early this morning, and still are. i really think “could be wrong” that its on there end thats causing the issues were seeing.
It is related to the server problems NOAA is having. I have already fixed that error on my next version to be released in a few minutes.
V2.00 03-Jun-2009 BETA .013
fixed all reported errors, all prior versions should be discarded. :lol:
Ok working good here, as in that error no longer there. Now have to wait for NOAA to fix there issue.
The latest works good Mike. My Advisory Is showing now that NOAA is back up.
Does it bother you that the title just says:
“Heat Advisory”
The old version it would say:
Heat Advisory - East Puget Sound Lowlands (Washington)
Should I try to fix that? Anybody?
I think it would be nice If it gave a little more detail where the adisory was. I like it now, But If you want to change it, I’d go for that too. Thanks for all the time you’ve put into this.
Well I think some may be used to the old way, then when they install the new script they will ask why it is different. Maybe I will add the feature as configurable an option.
Apparently this does not cover Short Term Forecasts, because this is showing it:
http://www.weather.gov/alerts/pa.html#PAZ066.CTPNOWCTP.221300
and this does not:
http://www.weather.gov/alerts-beta/wwaatmget.php?x=PAZ066
I wonder if it will cover the air quality alerts?
It does usually show Short Term Forecasts. They did have servers broken for most of the day so that might explain the omission.
Here is a national list of current alerts:
http://www.weather.gov/alerts-beta/us.php?x=1
Got a severe thunderstorm watch out for my county but it’s showing “There are no active watches, warnings or advisories for zone WVZ053.” This can be seen at http://www.harpersferry-weather.com/wxadvisory-2009.php. (use orange wide screen). The rrs-advisory-WVZ053.txt shows Jefferson County (WVZ053) with Severe Thunderstorm Watch.
The older rrs script shows the Severe Thunderstorm Watch at the top of my main page and also got the menu bar script showing the severe thunderstorm watch.
John
If an alert just came out, your cache file might not see it until the next refresh. you can force a refresh like this:
rss-advisory-2009.php?cache=refresh
It’s showing now. The watch had been out for quite awhile but I did a reboot of computer and now it’s showing.
Question though. In the rrs-advisory-2009.php I specified that the detailed report page is wxadvisory-detailed-2009.php but when I click on the link it goes to wxadvisory page.
I have $hurlURL = ‘wxadvisory-detailed-2009.php’
John
You are probably right about it being related to the earlier problems, it is showing now.
I don’t know John, the $hurlURL works on my tests
Could it be you have rrs-advisory-2009.php instead of rss-advisory-2009.php
V2.00 03-Jun-2009 BETA .015
- added feature/setting:
$doLongTitles = true; // <== change to true (default) to add the zone name to the Alert Title
// Heat Advisory
// Heat Advisory - South Washington Coast (Washington)
Is Ken going to have a stab at changing the rss-top-warning.php for the new warning system? Multiple zone script?
Keep up the great work gents…this is great stuff!
Its not showing the Place of the advisory, Just 2 brackets
http://www.snoqualmieweather.com/wxtest.php
$doLongTitles = true; // <== change to true to add the zone mame to the Alert Title
// Heat Advisory
Mark, you have version 14, version 15 fixed that.
