I have a WMR200 and I have been looking at how I will set this all up to ensure that the rain gauge and temperature/humidity sensor record accurately as possible. I am going to put everything together as there is a place on the property which meets all the criteria for the different sensors.
I am thinking about building a station house (for want of a better word) by getting an old louvre pantry door and using it to make a box which is approximately 1.2 metres above the ground to house my temperature/humidity sensor inside, putting the rain gauge on top, and the mast for the wind vane/anemometer attached to the side(see attached rough drawing). I will also attach my manual rain gauge to one side of the unit. I will use heavy duty pegs to secure it to the ground. I have used these pegs to secure other items to the ground and they can be easily pulled out with the right tools. The ground is clay so will hold well.
Considerations:
- I understand that the rain gauge should be approximately 1 metre from ground level, and the temperature/humidity sensor should be around 1.5 metres from ground level so a compromise needs to be found. I was thinking the top of the box would be approx 1.2 metres from the ground.
- The best location for the station is where I have to on occasionally drive thru (once or twice a year), so it needs to be movable.
- I was thinking of making the roof of the box flat so I can put the rain gauge on top, but I am not sure if it should really be sloping. I can still install the rain gauge on the top with different length feet.
Hopefully you all will give me your thoughts on my idea.
