I can’t reply to the thread in Weather Products/Services - Supplier Announcements so I figured I would start a new thread here.
You asked:
will it be a mv output?
The answer is no. We are developing a custom 1-Wire slave so that output will be in tenths of a UV Index. You will just need to divide the number returned by 10 to get the correct reading with the decimal point in the correct place.
The spatial response of the sensor is very close to a cosine model. I don’t have final information of the viewing angle yet as the final case has not been determined.
Windy,
We are not using a standard 1-Wire chip for the UVI meter as we couldn’t get the resolution we wanted so we have come up with a custom 1-Wire chip. I will provide more technical information and sample code to access the chip once everything is more finalized. It will be very easy and simple to access.
We were having a couple of issues getting some of the parts but we will hopefully have the UVI Meter in stock by the end of July or early August. It may take a little bit of time to get software support since we are using a custom 1-Wire slave so there will be new code involved but it is really easy to get the information from.
It will report UV Index in tenths so all the software will have to do is divide by 10 to get the UVI into a XX.X format.
$40 for a complex device with quite some time in the planning and design and testing phases. BTW you need the case with this one! (+$10.75) And attention to sealing off the RJ45 double socket and CAT5 cable connection.
We use the temp sensor for temperature compensated UVI readings but the main reason is to legally create our own 1-Wire slave we have to include a real Dallas 1-Wire slave chip on the board, so they get their cut of the money
