Author Topic: VirtualVP working only with Davis Advantage Pro?  (Read 2802 times)
Offline Mente
« on: April 27, 2009, 08:51:01 PM »
Hi.
I have a Cresta 815 LM weather station see http://www.cresta.nl/cresta_products/2/10/21/
Ihis station is with usb port, I am using WD and PC Wetter software.
Can I get virtualvp working with my weather station?
Mente
Offline niko
  • syzygy
  • Global Moderator
  • Northern California, U.S.A.
Re: VirtualVP working only with Davis Advantage Pro?
« Reply #1 on: April 27, 2009, 09:05:18 PM »
VirtualVP only works with the Vantage Pro. See http://www.softwx.com/weather/virtualvp.html
Offline SoftWx
  • Moderator
    • SoftWx
« Reply #2 on: April 28, 2009, 01:05:38 AM »
I'm not familiar with the Cresta, but unless it is a re-branded Davis Vantage Pro, then VirtualVP will not work with it. VirtualVP only works with the Vantage Pro. If the Cresta has a simple communications protocol, then you might be able to do the same thing that VirtualVP does by using two open source programs: com0com, and hub4com. They are found here: http://com0com.sourceforge.net/
The com0com + hub4com solution will work for weather stations that are send-only, i.e. they send data out over the serial connection, but they do not expect anything back.
Steve
SoftWx
