Thank You ! Problem solved by changing WU_URL as advised.
//Timo
//Timo
Trying to implement this script - little unclear on:
“The variables $maxtempyest and $mintempovernight must be made available either through addition to testtags.php or by other means.”
I am using Cumulus as my weather software - any suggestions/tips on what to do - don’t see anything obvious in the Cumulus forums - this file appears to be WD related.
I can get Cumulus to process a file and upload the data for maxtempyesterday and mintempovernight - but when trying the compare script it tells me that
The temperature variables must be initialized by running testtags.php or some other mechanism
Running testtags.php (by calling through a browser) does not help.
Guy
Guy,
Why don’t you attach a copy of the file that Cumulus is processing for you so I can understand better. A link to your site would be good too.
No problem. Here is the file that Cumulus processes (testtags.txt) it generates testtags.php
The scripts are in Index of /forecast
So the compare would be: http://www.wilsonsweather.host-ed.me/forecast/forecast-compare-include.php
The error has changed to configuration file not found - not sure why (I have been playing with root directory location in the scripts, but changed it back to the default).
Guy
testtags.txt (136 Bytes)
Guy,
Please rename the attached include file without the .txt and upload that. Hopefully that will fix the path problem which I think I caused in the file from the .zip.
Then please have Cumulus process the attached testtags.txt file. I’ve added code so we can view the actual output that it gives us by adding ?sce=view to the url.
Thanks. - Jim
testtags.txt (633 Bytes)
forecast-compare-include.php.txt (44.2 KB)
Running testtags.php?sce=view (which is what I think you mean?) simply displays www.wilsonsweather.host-ed.me
Guy
I’d say the next step is to find out where testtags.php actually is because it doesn’t seem to exist at http://www.wilsonsweather.host-ed.me/forecast/testtags.php. Perhaps Cumulus is uploading to the wrong place?
It seems to be there - if you go to http://www.wilsonsweather.host-ed.me/forecast/ its there - and I can see it in the directory when I use my FTP client. Odd.
Guy
That is very odd. When we try to run that script we get redirected to your main page. I don’t know why that would happen, perhaps someone else has an idea?
Why don’t you post that testtags.php here so we can see what it looks like.
Here it is.
The files all sit in html_public/forecast/ tried using that - no difference.
Guy
testtags.php.txt (623 Bytes)
Guy,
Let’s remove the downloader code that I added in testtags.txt to make sure that isn’t somehow causing the redirect. Otherwise I’m out of ideas.
The redirect was happening before the code was added.
Thanks for the help. I do wonder if the way my host structures directories plays a role.
My FTP client sees html_public/forecast/
But using the web file manager for the host shows home/wilsonsw/html_public/forecast/ (something like that). But even if I use those in config etc, makes no difference to the behaviour. I do have another web host I may try at the weekend.
Guy
Guy,
Please let us know how it goes with the new host. I agree that something strange is going on with the present host.
Well… My other host does not support php (with my package). Pondering this.
Guy
Hello,
I have been watching this WxSim comparator script for several days, the truth is that I liked it a lot. I would like to have it on my website.
I am trying to follow the instructions but being Spanish it is a bit difficult for me to follow the instructions in English. I am translating it and I try to understand, but I see that I do not clarify. I have started a couple of times but I do not see any data, only the empty table appears. I think the problem may come from the file testtags.php
Can somebody help me?
In case someone could help me, next I indicate the place where I have the files:
http://meteohila2.esy.es/pronostico%20mxsim/
thanks in advance
regards,
I can try to look at it tomorrow. Please post a link to the comparison script so I can run it.
Hi Jim,
thanks for answering!!!
next I indicate the link of the file forecast-compare
http://meteohila2.esy.es/pronostico%20mxsim/forecast-compare-include.php
when I execute this link:
[http: //meteohila2.esy.es/pronostico mxsim/forecast-compare-include.php? log & config = am](http://http: //meteohila2.esy.es/pronostico mxsim/forecast-compare-include.php? log & config = am)
I get the following message:
I do not understand it, as soon as the file testtags.php is running …
I found that your fc-temps.txt had some bad data in it, almost as if fc-LogTemps.php had never been run. I ran fc-LogTemps.php from here and now it has a high temp in it
30.1,23/08/2018 3:14 pm
and when you run fc-LogTemps.php to get the overnight low, there will be another temp between those two commas. If you’re going to use fc-LogTemps.php to capture the temps, you need to set up a cron to run it twice each day. I tried to explain that in the readme file.
Lets get that all done then we’ll see how things are working.
There’s something else to fix. In your config you say to use the yrno forecast, but that script isn’t giving me a good forecast. When I run http://meteohila2.esy.es/pronostico%20mxsim/yrfrcst.php I get only
1535033302 < && 1535033302 > Is night? 1
so you can check that out too while you’re waiting for the overnight low to be logged.
ok, for the moment we are going to wait, but I think it does not work !!!
