Author Topic: Can you use Virtual VP to update the firmware?  (Read 2606 times)
Offline G.O.B.B
  • Dayboro Weather.
  • Tomorrow I tell you today's weather.
  • Dayboro
    • Dayboro Weather Station
« on: January 25, 2009, 05:04:10 AM »
Can i use Virtual VP to update the firmware on the Vantage Pro 2 Plus?
If not how would I go about it? Do I have to uninstall VP?
Thanks in advance.
H.
Offline TNETWeather
  • Kevin Reed (KrelvinAZ)
  • Gremlins are at work...
  • Mesa, AZ
Re: Can you use Virtual VP to update the firmware?
« Reply #1 on: January 25, 2009, 05:33:04 AM »
The updater should be talking directly to the VP2 via its serial or USB port.
I have always turned off VitrualVP and the software that uses it while doing an update.
Offline SoftWx
  • Moderator
    • SoftWx
« Reply #2 on: January 25, 2009, 12:16:22 PM »
You definitely should update directly to the data logger. Stop all weather software, including VirtualVP.
After you've updated the firmware, you can then just start your software again.
Steve
SoftWx
« Last Edit: January 25, 2009, 12:17:55 PM by SoftWx »
