Author Topic: display error daily sunshine hours/ET graph for November  (Read 3806 times)
Offline MichaelPT
  • Staffordshire Nr Leek
    • Weather-Above
« on: November 25, 2008, 11:24:11 PM »
Hi Brian
I've just noticed a problem with one of the graphs please see image below
Every month displays correctly up to month of October
November the graph is not displaying correctly
I am using the latest version  build 16
Any chance you could tell me how to correct this graph
mick
« Last Edit: January 06, 2009, 10:31:55 PM by MichaelPT »
Offline griffith_500
  • Zurich, Switzerland
Re: display error daily sunshine hours/ET graph for November
« Reply #1 on: November 26, 2008, 09:36:30 AM »
Same error here as well...
Offline MichaelPT
    • Weather-Above
« Reply #2 on: December 01, 2008, 02:34:20 AM »
hi Brian
 have you had time to look at this  graph problem
mick
Offline Billw69
  • If you work hard, you will have time to play hard.
  • Evansville, IN U.S.A.
    • Evansville-Weather
« Reply #3 on: December 01, 2008, 03:22:36 AM »
I just took a look at mine. It appears to be working properly.
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #4 on: December 01, 2008, 07:13:55 PM »
its a quirk of the graphing component and the way it does the scale
(i.e its not my code)
the way around it is I need to set a minimum scale value, i.e make it a easily divisable value
.zip and email me your sun log file and I will see if I can do that
(112008lgsun.txt)
Offline MichaelPT
    • Weather-Above
« Reply #5 on: December 03, 2008, 12:52:26 AM »
Hi Brian
thank you for your response I have sent you an e-mail
with the file you've requested
mick
« Reply #6 on: December 12, 2008, 04:06:42 PM »
Hi Brian
Did you find a solution for this one? My graph is still corrupt.
Andy
Offline TokKiwi
  • Techno Dad
  • Mech Engineer and Hobbyist
  • Tokoroa, Sth Waikato, New Zealand
    • Tokoroa North Weather
« Reply #7 on: December 12, 2008, 06:10:34 PM »
Brian has been away for a week now and may not have had time to check it before he left.  Since this is in the Bug section then he should find it easily when he gets back.
TK
Dad's have hobbies because they are children's rugby, football and Committee Fathers!!
« Reply #8 on: December 29, 2008, 07:38:29 PM »
Brian, I'd really like to get some feedback on this bug and would like to know how you solved it.
Andy
Offline MichaelPT
    • Weather-Above
« Reply #9 on: December 30, 2008, 11:46:18 PM »
Andy
hi Brian
 in your latest version the problem of the  graphs are fixed
 thank you
mick
Re: display error daily sunshine hours/ET graph for November{not fixed}
« Reply #10 on: January 06, 2009, 09:25:41 AM »
Michael, I have installed the latest version and the graph is still unchanged and showing the error.
I would appreciate some feedback from Brian.
Thanks!
Andy
