Since I have been having so many problems with 2006 data, I decided to remove the data and log files for 2006. I ran the new sequence for converting log files. But my all time records still show 2006? What do I need to do to get this data out of there?
and every thing looks much better. But now there are some weird records for this month? It seems October wants to take over
These are all wrong and I’m guessing the “normal” way to reset them does not work.
Warmest Day (6AM - 6PM)
Warmest Night (6PM - 6AM)
Coldest Day (6AM - 6PM)
Coldest Night (6PM - 6AM)
Highest October Temperature
Lowest October Temperature
Highest Daily Wind Run
Highest Monthly Precipitation
Highest Precipitation Rate
Consecutive Days With > .01 Precipitation
Consecutive Days Without Precipitation
Highest Solar Radiation
Highest UV Index
Highest August Temperature 93.9 2008 But was really August 7th 2007 95.9
Highest September Temperature 93.9 2007 But was really Sept 4th 2007 94.2
I seem to have started something here. To answer, No it is not running all the time . I run in the morning first thing and then again in the evening.
When I do the manual reset this is through (action reset all time records when you physically see the setting change to 50 or -50 I do believe this is a program malfunction.
Also, why do the October warmest and coldest temperatures show under ALL TIME RECORDS. and not THIS MONTH. Surely under All time records this should show what is ALL TIME.
That the program sets it the WARMEST temp to -50 (notice the negative value) and the COLDEST temp to +50 (notice the positive value) is not a malfunction.
That is simply to make sure that any new/forthcoming record will be registered.
I realize that it needs to cycle one time to get going. But it is not showing any previous dates. I can tell you from fact that we have had a couple of warmer/cooler days/nights before today
And what happened to these dates?
How does the solar records get reset?
And the Wind Run?
And some of the perspiration records are right and some are just the last 24 hours?
Have done this but with no avail. I program has been running 2 hours before 6pm and 2 hours after 6pm but still the warmest night is -50 and the coldest day is 50
Regards
Burgus, the warmest day/coldest night calculations are not done (at the moment) from the convert logfile to data file
so if you had reset those values, then they will not get re calculated via the conversion
How do I do it?
And what about these items?
And the Wind Run?
as I posted, at the moment, those warmest day/coldest night calculations are not done from the log to data conversion
re your last question, when you say they should be such and such, where are you getting those values that it should be from?
(if those values are not in the logfile then it will not get picked up)
