hi Brian
I am still having problems with the wireless extra temperature sensor 3 hi/low reset buttons are not working
in the Graph you will see a brown line this is the dater from sensor 3 and is displaying as millivolts ?
it seems that the solar sensor is somehow interfering the extra temperature sensor 3
the graph is fluctuating between the actual temperature from sensor 3 and the mysterious millivolts dater
my setup is exactly as Bashy the only difference is he is using a solar jar for his solar sensor
I am using a hobby board solar sensor
could you please try to fix this as I have run out of things to try this is stopping me from adding my soil sensors/cloud sensor
wireless extra temperature 1 is used for the UV mod
wireless extra temperature 2 is used for rain duration mod
mick
what sensor have you set to plot in that data position?
hi Brian
mick
hi Brian
what sensor have you set to plot in that data position? { wireless extra
temperature 3
thanks
but there is no selectiong available for wireless extra temp 3
there is though for extra temp 3
is that what you have selected?
hi Brian
mick
sorry extra temp 3 is selected
mick
with build 19 update, when you go to view, wmr968/100/200
what do you see showing for the temperature from your wmr968 extra temp/hum 3?
hi Brian
mick
hi Brian
with build 19 the temperature and humidity are showing I only have a extra temperature sensor cable/ probe unit no humidity
[color=red] the temperature is displaying 19.2 c then after a few seconds it jumps up to 21.6c
reset button for high /low not working[/color]
[color=purple]humidity reset buttons are working and there is 50% humidity being displayed
[/color]
image 1 build 18
image 2 build 19
thanks
do you have a wmr968 extra temp/hum # 3 sensor
hi Brian
mick
hi Brian
[/color]
image 1 build 18
image 2 build 19
thanks
no
wmr968 extra temp with probe
windy2
3 October 2008 09:00
10
do you mean its a temp only sensor?
(I am now finally understanding what sensors you have in use)
what other types of wmr918 extra temp/hum sensors do you have?
hi Brian
mick
yes all are temp only
Temp 1 is for the uv mod
Temp 2 is for the RD mod
Temp 3 will be used as cloud senser
windy2
3 October 2008 19:50
12
and the other 2 temp only wmr918 sensors work OK?
also does the extra temp #3 show up OK , the value, above the windspeed dial, on the wd main screen (as long as not set to show windrun there)
hi Brian
mick
other 2 temp only wmr918 sensors work OK yes
yes
the data scrolls through the sequence
solar
temperature 1
temperature 2
temperature 3
temperature 1
solar
temperature 2
temperature 3
temperature 1
mick
thanks
windy2
4 October 2008 03:39
14
I suspect that the problem is, is that you have set extra temp 3 to be soil temperature
in the view, extra sensor real time graph, at the very top of the setup screen for that (click on setup)
hi Brian
mick
hi Brian
have set extra temp 3 to be soil temperature No this is set to (0)
it’s strange that the high and low reset buttons do not work
and in the real-time graph, extra temperature 3 which is labelled test is displaying as millivolts and it fluctuates for a few seconds
from the correct temperature to some phantom data
mick
windy2
4 October 2008 19:08
16
.zip and email me your settings files and I will check on some things
hi Brian
I have sent an e-mail with settings files etc
thank you
windy2
5 October 2008 07:04
18
ok
since you have a 1 wire solar sensor, that plots as on line #7 on the extra sensor real time graph
so , set another spare line to plot extra temp 3
ok
hi Brian
I set another spare line to plot extra temp 3
and reeorganised the other sensors please see image below
millivolts has now disappeared from graph
high and low reset buttons are not working still
and the data is still fluctuating it is going up to 18.9 for a couple of seconds then dropped down to 10.9 which is the correct temperature
I would like to have extra temperature 3 as a cloud sensor I have set up the settings for this the dater
is fluctuating
hi I’ve just updated weather display with the latest version
and the extra sensor 3 display box is now displaying humility there is no humility sensor on these channels please see image
thanks
windy2
5 October 2008 23:21
20
i found the obscure settings problem
go to view, auto scale graphs
then untick
plot indoor temp/hum on the extra sensor #3 graph
(right down the bottom)
and then restart WD
Cheers
