The cloudbase graph you show is WD estimate cloudbase: the height at which the water vapour condensates and make a cloud (if any). This does NOT mean there could be a cloud. This estimation is only valid for low level clouds. The tags for this value are:
%cloudheightfeet%…Estimated cloud base height, feet, (based on dew point, and you height above sea level…enter
%cloudheightmeters%…Estimated cloud base height, metres, (based on dew point, and you height above sea
If you have a near Metar station you can retrieve it with WD and show with different tags:
%weatherreport% …current weather conditions from selected METAR
%metar/report=%NZAA.MET Insert downloaded METARS or weather reports/warnings.
Please replace NZAA.MET with the file name downloaded.Note: use
and
html tags
%uncodedmetar/report=%NZAA.MET Un decoded (raw) only
%downloadedmetar1extrasky%.Sky conditions
%downloadedmetar1sky%…More sky conditions
%downloadedmetar1cloud%…Cloud conditions or weather
%downloadedmetar1press%…Barometer reading
%downloadedmetar1humi%…Humidity reading
%downloadedmetar1dewp%…Dew point reading
%downloadedmetar1temp%…Temperature reading
%downloadedmetar1tempcelsius%…Temperature reading in celsius
%downloadedmetar1wind%…Wind readings (speed and direction)
%downloadedmetar1location%.Metar name and time stamp
%downloadedmetar1vis%…Visibility
%downloadedmetar1name%…Just the metar name. (1st 10 metars only)
%downloadedmetar1time%…Just the time of update.(1st 10 metars only)
%downloadedmetar1rainlasthour% Rain in the last hour (if its available)
%downloadedmetar1windonly%…Shows just the windspeed only (1st 10 metars only)
%downloadedmetar1dironly%…Shows direction in letter (1st 10 metars only)
%downloadedmetar1dironlydeg%… Shows dir in degrees.(1st 10 metars only)
Repeat this for up to 50 downloaded airport metars (i.e %downloadedmetar2location% for the next one)
There is also a set of tags that I think they only work un the US:
US Navy
%usnavycloudheight1%…Cloud height from the ceilometer, feet
%usnavycloudheight2%…Cloud height from the ceilometer, feet
%usnavycloudheight3%…Cloud height from the ceilometer, feet
%usnavycloudtype1%…Cloud type
%usnavycloudtype2%…Cloud type
%usnavycloudtype3%…Cloud type
%watertempcelsius%…Water temperature, oC
%watertempfaren%…Water temperature, oF
%visibility%…Visibility (miles)
%visibilitykm%…Visibility (km)
