The link shows me this. In IE7 and FF.
Bill,
Your xml file is not in the proper format. How did you create it?
I copied this site, and changed as I thought it was needed.
http://www.carterlake.org/sitemap.xml
Basically I just changed the url’s and the frequency. then deleted the pages that I don’t have.
You have to look at the Source of of the page, not the output of the page as you may see it when you look at it with a browser…
There are no Dashes in the “source”
sample-sitemap.txt (347 Bytes)
ahhh. my mistake. #-o I’ll remove them, and try again.
ok. Dashes are gone.
illegal space before the xml start…
`XML Parsing Error: XML or text declaration not at start of entity
Location: http://www.evansville-weather.com/sitemap.xml
Line Number 1, Column 3:
well darn it. I’ll go back and delete the spaces now.
EDIT: All spaces have been removed.
Thanks for the help guys!
Bill
Hi guys,
which metatags should i edit to have the result in attachment?
Thanks in advance,
Alessandro
This one Alessandro:
<meta name="description" content="See live weather from the Outer Hebrides in Scotland. Includes time lapse movies, forecasts and actual weather conditions updated every few seconds.">
Thanks Martin!
Google is stripping the “.php” on my Contact page Link and its saying its a bad link. As you can see in my sitemap file, it shows the .php
http://www.snoqualmieweather.com/sitemap.xml
Anyone know why Google might be doing this? Ive resubmitted my sitemap through there webtools, but that hasnt helped at all. Thanks, Mark
Maybe there is something about the page it doesn’t like.
I note that you start off with a tag before the DocType.
Your sitemap is OK. Google has a cache of an old contact page you had at that URL
You can see it is the top link on this search
http://www.google.com/search?q=site%3Awww.snoqualmieweather.com+contact&ie=UTF-8
This is Google’s cache of http://www.snoqualmieweather.com/contact. It is a snapshot of the page as it appeared on Aug 8, 2008 04:35:32 GMT. The current page could have changed in the meantime.
You just have to wait for google to purge it out naturally or you can make a mod rewrite to 301 redirect that old URL to your new URL
The redirect help if anybody clicks on the google link, but they probably would contact you from your site anyway.
Great Info from ya Both…I’ll wait and see if Google will fix it them selves. Does it help any if i resubmit my Sitemap file in there webtools to maybe speed things up?
gsitecrawler can ping google when it uploads your sitemap, but google will usually come get it when ever it wants. I would not worry about it.
It may take several days or even several weeks for google to purge your old pages, you just have to wait.
I`m confused… 8O can somebody guide me step by step what should I do?
Should I dl one of these two(photo)? should I create a file called robots.txt and enter in the text? and then uploaded to the website?
I got mine running. The bots were all over my WUHistory and radar files so they are now removed from being crawled. This was pretty simple and I was quite impressed with what google had about my site all ready. Thanks for the info on getting this up and running.
If I understand this correctly Google will look at the sitemap.xml and then index the site nicely as it has done with Carterlake’s or TNET’S site? And this could take from 6 days to 6 months? So far google says my sitemap is acceptable just wondering what happens next!
Jack
It takes a while…
I stopped looking and then when I checked one day it was there.
