When you create a custom screen such as a banner (like mine below), and set the update and upload times, it gives you an option to set the size, and a check box saying “Use this size” or similar. 'I’ve been creating my custom screen background images in Fireworks to a fixed size, and using that size as the overall size of the graphic I want the custom screen to produce. So I set those sizes in the update create times setting box, but the outputted file is never to the dimensions I set. I have to offset the sized by trial and error. So that needs to be fixed. Also when you reopen the update upload settings box, the width is remembered from your previous settings, but the height is not - it’s reset to the same as the width.
it depends on your windows version
which windows OS?
and the next update of wd will fix that height setting not being remembered
I’m running XP pro here (version 2002 service pack 2). I don’t understand why it would depend on the windows version. Pixel size is a relative size on any OS isn’t it?
