Not sure where to post this, but here will do.
I have spent some time expanding on Carterlake’s system for converting WD tags to php. In the process I have also come up with a good tag reference page for users who aren’t using php also. You may also find some other goodies from here as well.
See http://www.newton-noss.co.uk/weather/tech/
For every WD web site builder
The tags reference page is pretty useful, because you can easily go to the section you want, find the tag you need, and see a sample of what it will output.
For PHP junkies
This is an expansion of the Carterlake php tags system. I have added a raw tags file containing every WD tag, and you can use the WD tags reference page to find the tag you want to use, and get the ID number for it, to include in the php code.
I have already found this very useful, so I hope it might be of use to others too.
