would it be possible on the data table that weather display does, to add the uv value? I do see that the solar value is also on that table. UV would be a nice addition.
A custom table that shows UV. Attached is the wx35local if you want to use the codeā¦
wxlocal35.html.txt (20.2 KB)
I appreciate the file.
uv should work OK on the default web table
it is for this web site:
http://ps.gen.nz/~hamgap/waiuku.htm
make sure you have ticked that you have a solar +uv sensor in the weather station type setup, davis setup
