I’ve been running StartWatch with VVP for more than one year now, no problems at all. Moved to WeatherLink 5.8 in January this year and things just got better.
Here’s the unwise part: I recently changed security suites (from Kaspersky 7.0 to Norton 360 2.0) AND allowed Microsoft Update to install SP3. Too many changes almost at the same time!
After the changes, and only occasionally when powering up, everything goes through the normal sequence (StartWatch, VVP, WeatherLink) and then, when all is running, I get an odd error message, apparently from the Microsoft software. The error message says, in part, "Provides virtualized access to a single Vantage Pro con has encountered a problem and needs to close. We are sorry for the inconvenience. If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem." And there’s a two button option [Send Error Report] [Don’t Send].
Whichever button I click, sure enough VVP closes and console connectivity is lost.
However, if I then restart VVP manually, all is usually OK. Or if I shut StartWatch down, killing the programs it started, then restart StartWatch, all seems OK. In that case, it appears that there are two copies of StartWatch in memory.
A few more details:
Microsoft XP SP3 Build 2600
StartWatch 1.1.1.144 (Registered)
VVP 1.1.1.2 (Registered)
WeatherLink 5.8.0
Has anyone else seen anything similar? It seems at first glance as though the error is coming in through Win XP SP3 since the error message is a Microsoft error message.
Thoughts appreciated. Jokes about changing things simultaneously when everything had been working just fine tolerated with good humor.
Bob Owen
