Hi Folks!
After many tweaks and tests and a total rewrite of the script with help of Jim (jmcmurry) its time for release for vers 1.0
Its started as a bandwidth-saving-project (Nexstorm main-image can be a real bw-eater), so it only use the map from Nexstorm and the data it shows with ajax from customclientraw- and customlog-files. One of the main-ideas is to update the data (image or data) only when new data is aviable. The script include a JpGraph-template to make a 24 hour-graph of lightning with data from customlog-file.
The script is in two versions, a standalone-version and a version customized to fit the Carterlake-template. It also support multilanguage and shows a offline-image if map is older than 1 hour.
The dark-grey stuff you see in the right image’s right sidebar, are planned for vers. 2, and not included at this stage and not showing in the releases. They are strikes by type and peakrate.
Click on images for live demos of them.
The projectpage and download you find here.
Henkka
