Author Topic: Fog Icon but I don't have any.....?  (Read 1358 times)
Offline geewizard
  • Greenacres, WA
    • Greenacres, WA
« on: November 30, 2003, 04:46:56 AM »
I've seen posts about users having fog but no fog icon showing up.
I've got the fog icon but no fog.  Even when I set the fog icon temp to it's lowest setting (-10C) and my humidity is at 90%, I still get the fog icon and the "current weather" reads fog.  It's CAVU.....
any ideas, weathermen/women?
Geewizard
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #1 on: November 30, 2003, 04:53:05 AM »
humm...
are you using a metar to update it maybe?
but if the current condition says fog:
try setting the fog icon threshold to 100%
Offline geewizard
  • Greenacres, WA
    • Greenacres, WA
« Reply #2 on: November 30, 2003, 02:48:52 PM »
No metar, the fog icon temp threshold set to -10C, the fog icon humidity threshold set to 100%.
In general, how is humidity measured when the temperature is below freezing?  I think my humidity sensor must be frozen.....
Geewizard
  • Davis VP2
  • New Zealand
    • Weather Display
« Reply #3 on: November 30, 2003, 04:22:20 PM »
humm, it still should not get shown....check also though under input daily weather you do not have it set there
humidity sensor:
its a capapacitor type sensor usualy.....as long as no moisture on it to freeze it still shoule keep working
its great to think i have a wd users in alaska and near the south pole
Offline geewizard
  • Greenacres, WA
    • Greenacres, WA
« Reply #4 on: December 02, 2003, 03:56:46 PM »
No, it's not set under "input daily weather"  What I did to stop it is offset the humidity by -1% as a test.
I'm honored to be the furthest north user of WD!  I will endeavor to bring you the latest in cold weather issues.
Geewizard
