Hi All,
I was looking Clientrawextra.txt field 531 it shows —
it is the wd or vp forecast field what do i have to set so it will work
thanks thanks Beau
Hi All,
thanks thanks Beau
Control panel
→ Summary Image/Icons setup
----> tick show Davis VP forecast ticker on main screen.
Keep in mind that VP forecast needs a fair few hrs before it can do a prediction. I can really recommend WXSIM it is excellent in weather predictions.
Hope this helps.
Henk.
he does not have a Davis VP station so it will not work
is there a way to do it with a station is not a davis vp
thanks Beau
your station type only gives very basic forecast, eg rain/sunny/cloudy, as opposed to the verbose Davis forecast,which you can get via the icon type if you set the icon to be updated from the station
but you can set a downloaded noaa forecast to come through on the davis VP forecast
hi Brian i have checked use the forecast for the vp forecast system
i m download the forecast 531 is still blank
Beau
its not clear what that means
but, have you set up the 5 day forecast, from the downloaded noaa forecast, and does that work correctly
Hi Brian, yes the noaa forecast is downloading
but Clientrawextra.txt fileld 531 is —
thanks Beau
Hi Brian
yes i have set up the 5 day forecast an it downloads every hour just fine
Beau
here what i get from the downloads
Beau
Expires:200805031130;;281215
FPUS53 KILX 022027
ZFPILX
ZONE FORECAST PRODUCT
NATIONAL WEATHER SERVICE LINCOLN IL
327 PM CDT FRI MAY 2 2008
ILZ042-048-051-031130-
LOGAN-MENARD-SANGAMON-
INCLUDING THE CITIES OF…LINCOLN…SPRINGFIELD
.TONIGHT…MOSTLY CLOUDY. ISOLATED SHOWERS AND THUNDERSTORMS EARLY
IN THE EVENING. LOWS IN THE UPPER 40S. SOUTHWEST WINDS 15 TO 20
MPH. CHANCE OF PRECIPITATION 20 PERCENT.
.SATURDAY…MOSTLY CLOUDY. CHANCE OF SHOWERS IN THE MORNING.
HIGHS IN THE UPPER 50S. BREEZY. WEST WINDS 20 TO 25 MPH. CHANCE
OF PRECIPITATION 30 PERCENT.
.SATURDAY NIGHT…PARTLY CLOUDY. COLDER. LOWS IN THE UPPER 30S.
NORTHWEST WINDS 5 TO 10 MPH. GUSTS UP TO 25 MPH IN THE EVENING.
.SUNDAY…SUNNY. HIGHS IN THE UPPER 60S. LIGHT EAST WINDS
BECOMING SOUTHWEST IN THE AFTERNOON.
.SUNDAY NIGHT…PARTLY CLOUDY. LOWS IN THE MID 40S. SOUTH WINDS
5 TO 10 MPH.
.MONDAY…MOSTLY SUNNY. HIGHS IN THE LOWER 70S.
.MONDAY NIGHT THROUGH TUESDAY NIGHT…MOSTLY CLOUDY. LOWS AROUND
50. HIGHS IN THE LOWER 70S.
.WEDNESDAY…MOSTLY CLOUDY WITH A 30 PERCENT CHANCE OF SHOWERS
AND THUNDERSTORMS. HIGHS IN THE LOWER 70S.
.WEDNESDAY NIGHT…MOSTLY CLOUDY WITH A 40 PERCENT CHANCE OF
SHOWERS AND THUNDERSTORMS. LOWS IN THE UPPER 50S.
.THURSDAY…CLOUDY WITH A 40 PERCENT CHANCE OF SHOWERS AND
.THURSDAY NIGHT AND FRIDAY…MOSTLY CLOUDY WITH A 30 PERCENT
CHANCE OF SHOWERS AND THUNDERSTORMS. LOWS IN THE MID 50S. HIGHS
IN THE LOWER 70S.
what I mean is, have you selected that file to use for the 5 day forecast system in WD
in the noaa download setup
so that when you click on the main icon on the WD main screen then you see the 5 day forecast screen
yes i did pick a file an if i click the icon it shows up
Beau
