I have a little problem with my wx-pc. It self-close internetconnection (adsl) every now and then #-o and only way to reconnect is reboot the whole machine and now I wonder what it could be what cause it?
Specs:
3000+ AMD
1 Gt ram
Vista SP1 (I have tested with XP too but problem are still there)
When you say normal ADSL connection what exactly do you mean? Is there an ADSL modem connected to the PC and want is used to connect it (USB or other) or do you have a router on a local Lan? It makes a huge difference.
What make and model modem is it?
On the modem configuration screen does it have a setting to keep connection alive always? make sure it is enabled.
some modems come with a default to disconnect after XX amount of time of inactivity (you do not want that)
No need to change that, do you use “obtain IP address automatically” in Vista DHCP settings?
also check ‘Wan Connection’ modem configuration page you want “Connection” set to “Always On”
and on most modems you should also set “Idle Timeout” to 0
I don’t have those options in my config what are in the manual, maybe cause I use 1483 Bridged IP LLC (its autoconfiged/configed by ISP).
And the most strange, my pc closed the internet for me just for about 30 min ago when I worked on it. It just stopped get stuff from internet (and upload wxstuff) and only way get connection back was reboot and the second computer wich is connected to the modem via the WLAN worked just fine… #-o
That’s good to hear someone else have had same kind of problem No, I haven’t asked them yet but can do it tomorrow, if I remember when their problem-line is open. I often rember these kind of stuff wich not critical in the evening when they are closed LOL
