I’ve looked but cannot see how to reduce the size of summary.gif. I need to make the overlay the same size as the background image so that the text appears crisp and sharp when the two are viewed together.
Can someone point me in the right direction, please?
Cheers to all!
John
try:
setup, advanced/misc, then main screen
then tick to enable customisation
then you should be able to resize it
then go back and click on save changes
John, use the Ctrl key with the mouse pointer only. Start on the bottom right and reduce overall size, Shift & mouse to move things.
Graeme
So much to learn! #-o
Brian, I followed your tips and was able to resize it and the text is crystal clear now!
Thanks!
Graeme,
I will (try to) remember that tip!
Cheers
John
that only works though if you have enabled to modify it under the setup, advanced/misc first
and to resize the whole thing, you just use the normal mouse arrow when the mouse is over the bottom right corner,
but to resize other things on that screen, then do what Graeme said…
Thanks for the additional info, Brian, but I ain’t gonna touch it now because it looks good!
It’s on my brother’s website, so I have no doubt that when his WX is installed, up and running, there will be a new forum member asking you all questions!
Cheers
John
