All time Gust speed not correct
Yesterday I recorded 49 mph wind gusts… if you look at my historical data it shows that. My 24/48 hour charts also reflect it… but for some reason on my all time highs, I see a speed of 38 mph that occured a couple hours after the actual highest gusts… Could you take a look at that routine whenever you get a chance? Thanks Brian!
i did fix it where with the complete record mode, and use max gust, when it occured, it would check it then for against the all time records…
what vers of wd ?
Do you mean I need to have both the Ultimeter and the ‘use complete record mode’ in WD set respectively?
I can double check… and I’ll bring down 9.97d as well…
Thanks!
