FTP Download
I’m haveing a problem trying to get the extended forecast from
noaa I do the test and it does it’s thing says error code 550
and then retries and I get the file but it’s blank nothing in it??
I have checked and rechecked the path and file name all is good
any idea’s???
what have you set for directory path and file name>?
copy/paste to the forum here
Hey Brian here’s the stuff
Host Name
weather.noaa.gov
Directory
/data/forecasts/state/wa/
File Name
waz.007.txt
It did work once but the forecast5.gif file only had a background no info…
Thanks Brian
data/forecasts/state/wa" is current directory.
Retrieving the NOAA file waz.007.txt now
PASV
227 Entering Passive Mode (205,156,51,200,136,216)
RETR waz.007.txt
550 waz.007.txt : No such file or directory.
141: 550 waz.007.txt : No such file or directory.
Finished ftp download
QUIT
that file does not exist on the server
it must have changed…
try doing a search on their server for a replacement
(click on that link in the ftp download setup in wd)
Have you got 2 periods in the file name? Looks like waz.007.txt. Should be waz007.txt - no?
Yes I saw that and let Brian know it should not have 2!
Thanks!!
i managed to get it to work
but i too had problems initialy
re typing in the directory to use and the file name to use, instead of copying/pasting, did the trick
which gets rid of any trailing or leading spaces and any command characters like CR or LF
Well it seems I am getting the file all the time now but when I
set it up to use the forecast5day.gif file in my web page it will
work for awhile then everything goes away except for the background
clouds?? This must be something when WD converts the file??
You may like to try this address if you are not already using it.
ftp://tgftp.nws.noaa.gov/data/forecasts/state/wa/waz007.txt
When the forecast5day.gif file fails to display on the web page look in the FTP download directory you set up in the FTP/Metar download page. Is there a .txt file there? Ascertain the time of the file and what the file contains. The file should be your 5 day forecast.
If the weather service transmits a “TABULAR FORECAST” it may cause the problem. You may determine what is in the file by using the above procedure.
Yes it did say Tabular Forecast…And I have tried both URL’s and they
both do the same…There is a text file and it is all there I was getting a blank file for awhile!
yes, wd expects it to be in a certain format…like this below…any thing else and it wont like it
.TONIGHT…RAIN CHANGING TO SHOWERS BEFORE MIDNIGHT. CHANCE OF
THUNDERSTORMS ON THE COAST LATE. LOWS IN THE 30S.
.MONDAY…SHOWERS LIKELY. HIGHS IN THE LOWER TO MID 40S.
.MONDAY NIGHT…RAIN AND WINDY. SNOW IN THE MOUNTAINS. LOWS IN THE
UPPER 30S AND LOWER 40S.
.TUESDAY…RAIN AND BREEZY. SNOW IN THE MOUNTAINS. HIGHS IN THE
LOWER TO MID 40S.
.TUESDAY NIGHT…RAIN. SNOW IN THE MOUNTAINS. LOWS 30 TO 40.
.WEDNESDAY…RAIN LIKELY. HIGHS IN THE LOWER TO MID 40S.
.EXTENDED FORECAST…
.THANKSGIVING DAY…RAIN AND WINDY. LOWS 35 TO 40. HIGHS IN THE
LOWER TO MID 40S.
.FRIDAY…SHOWERS LIKELY. LOWS IN THE 30S. HIGHS 40 TO 45.
.SATURDAY…MOSTLY CLOUDY WITH A CHANCE OF RAIN. LOWS 35 TO
40. HIGHS 40 TO 45.
.SUNDAY…MOSTLY CLOUDY WITH A CHANCE OF SHOWERS. LOWS IN THE 30S.
ok, i too get the blank…with the above forecast
i will have to investigate
I think the weather service forecaster (employee) determines the format of the forecast when the forecast is posted. I see both formats used. :cry:
i did another test of using this forecast file, and it came up OK for the forecast image././/
Well I have it downloading the file now but now WD is not making
a new forecast5day.gif file…I deleted the old blank one and no new one is showing up!
now, does it look ok in the program?
re updating:
do you have it set to do a upload?
it should do that after it downloads the file
Hey Brian so far so good I’ll know in the AM it seems to change on it’s own so I will have to wait awhile and see I’ll let you know tomm…
Well So far so good Brian! I’ll keep an eye on it for a little while and see
how it does!! Thanks
Must be the afternoon forecast that is messing things up It is blank again after the 3pm download…I am going to try and just downlaod in the AM
and see what happens!!
I'm haveing a problem trying to get the extended forecast from noaa I do the test and it does it's thing says error code 550 and then retries and I get the file but it's blank nothing in it?? I have checked and rechecked the path and file name all is good any idea's?????
steve,
Curious where you found the waz007 for your location. my metar station is KSAF. im trying to do what you did, but i need this to download the txt file. ive looked everywhere. location is santa fe, nm.
thanks,
joe
