hi everybody
I seem to have a problem with my links on the main webpage which is created by weather display
how do I change or had coding so the links are going to the correct folder
my existing path was www.weather-above.com
the new location where the data is being uploaded to is www.weather-above.com/public_html/
please see image below every link is not displaying correct data I just get a blank page
when I right click on the link I get the following location http://www.weather-above.com/yesterdaygraph.gif
this brings up the graph
if I just click the link I get the following www.weather-above.com/Mainpage%20logs.html
can anybody help
mick
You should be able to add the directory in the ftp setup page…there is a box under the login details that says directory.
There are no missing graphics for except on another page… - oh, its there now - it all seerms ok.
I would save the WxSim graphic as a customscreen and then as a gif or png. Then it will be much smaller - see the Sticky…
Graeme
thanks for looking so when you click on the links you can see the graph
if this is the case something somewhere in my browser is blocking the images
mick
hi Dan
I have entered the information in the directory setup page
the data is there but if I click on the links they just display a blank page
is this what you are seeing ? Are you getting a blank screen
thanks
I had no problem when clicking on the buttons, everything I tried worked ok. And this link, http://www.weather-above.com/Mainpage%20logs.html , works ok for me also. I’m not seeing a problem…
I am using Opera 9.25 and all the graphs worked, even the yesterday.gif. But I didn’t know what links you were using - I used those on several pages including the data table page and the drop down menus.
Cheers
Graeme
hi everybody
I am using Internet Explorer 7
if I right click on the link then select open in a new window the graph displays
is there a setting somewhere that will do this automatically in Internet Explorer 7
mick
Bashy
30 March 2008 14:22
9
Hi Mick
you need to open in a new window…
<a target=“_blank” href=“http://www.test.com ”>test
This won’t help solve your problem, but in FireFox, your web page loads and displays
all images just fine for me.
-Keith
I think I’m going to install Firefox I knew nothing about this browser
do I need to uninstall the Windows Explorer browser
mick
No, you can have both on your PC at the same time. You can set FireFox to
be your default browser, however, so it starts instead of IE.
-Keith
