VVP not connecting
Steve, I had problems with the clientraw file in WD not updating and did several reboots of the computer. I’m using StartWatch to start all weather programs including VVP. Each time I reboot VVP will start but does not connect and startwatch displays that it is not connected down in the Ports section. Sorry can’t remember the exact error message.
To make it work all if have to do is start VVP from a shortcut and I can see it downloading the archive and all is well.
–Dave
Dave I had a problem similar to that the other day and my problem was that I did not have the IP addresses plugged in correctly in VVP and therefore Startwatch was checking the wrong IP.
Bump
Can you email me the log.txt file from the VirtualVP folder, and tell me the date and time the problem occurred so I can find the matching output in the log.txt file? Has the problem happened again since the first occurrence?
Sending the file shortly. Happens each time I reboot the computer.
–Dave
