My pc messed up like 2 weeks ago i have reinstalled wd like 6 times now. Now it saves all my old settings no mather what Dir. i install to,so cant do clean install. I get irox data runs way to long, cant even open data logger from control my temp just flashes in red 72 F its like 46F and rest is all off readings i should have.I am going nuts on reinstalls. How i do clean install if it still sets my settings wrong (old setting that don’t work now) Running windows xp wd 10.37i
you need to create a file in a new directory called 2wd.txt (or 3wd.txt)
to start with new internet/web etc settings
or run regedit.exe and search for wdisplayftp.ini and then delete that from the registry
