Hamweather & Humidity
I’ve been using my local METAR, downloaded from weather.noaa.gov, to import the humidity value. This has been working good for me. However, for almost the past week, the METAR’s from the noaa server have been 2+ hours old.
Tried using the hamweather.net server instead. It is updating the METAR on-time. Only problem is, WD is not importing the reported humidity value into the main display. Any fix? Thanks.
Dave
North Babylon NY
ah, the hamweather is different routine…
i may not have put in the humidity import…
what metar are you using? (4 letter code ) and i will check it out
KFRG is the one I’m trying to use. I’m running version 9.96a. Thanks.
i have fixed it
uploading a new 9.96a now
check for the new time on the file in a few hours from now
Thanks Brian, works good now.
I've been using my local METAR, downloaded from weather.noaa.gov, to import the humidity value. This has been working good for me. However, for almost the past week, the METAR's from the noaa server have been 2+ hours old.
Dave
North Babylon NY
Hello,
I have the same trouble with the Geneva’s Metar… Always very late sometimes more than 2 hours… Is there any other good source to get it and use it in WD???
my code is LSGG . thanks for your help…
:wink:
